Fuel pump always running
Old Jul 15, 2009 | 10:13 AM
mikesz's Avatar
After getting all the little things worked out on my z.The fuel pump was priming for the the 5 sec period just yesterday and today it just keeps running with the key in the on position.
I checked and cleaned all connectors ect.I wired in my own fuel pump relay when i did my turbo swap(four years ago) and thought that was problem,Put a new relay in and no change.The car will start,but won't idle.It revs just fine.I have to keep my foot on the gas or the engine will stall.Keep in mind this just happend today.The car was running strong yesterday with no issues.Any ideas on what the problem maybe?
Old Jul 15, 2009 | 10:49 AM
Keep in mind that I bypassed the fuel pump controller on my turbo Z which regulates between 14v and 9v for idle. My car still idles smooth and the fuel pump runs all the time with the engine on. The lower voltage was to decrease amperage draw and noise, not to aid in running at idle. The system still primes for 5 seconds before startup, but once the engine is started, the fuel pump runs continuously.
The system should keep the proper fuel pressure regardless. I would look first to a faulty fuel pressure regulator on the fuel rail.
Old Jul 15, 2009 | 10:57 AM
mikesz's Avatar
Thanks for the advice.The one thing i forgot to mention was i changed my boost gauge connection and tied into the fuel pressure regulator.That maybe the problem.I'll post back the results.
Old Jul 15, 2009 | 12:03 PM
mikesz's Avatar
Just got back from working on the z.Re-locating the boost gauge hose didn't change anything.The fuel pressure regulator seemed ok.I'm starting to think i may need a new pump.Would the fuel pump still operate even if was faulty?It seems louder then usual.
Old Jul 15, 2009 | 12:58 PM
mikesz's Avatar
I take back stating that the fpr is ok.I forgot i do have an extra one to install.I'll install the extra one and see what happens.
Old Jul 15, 2009 | 02:28 PM
audiofreak97's Avatar
Oh yeah?! Freak this!!!
I have the same problem after I did the head gasket a couple years ago. It primed for 5 seconds before the head gasket and just ran and ran after. When you figure it out let me know.
Old Jul 16, 2009 | 12:13 PM
mikesz's Avatar
Well, I put the other fpr on today and still no change.If anyone has had this problem in the past,Please let me know.I don't want to go out and buy a new fuel pump if i don't have to.
Old Jul 16, 2009 | 01:04 PM
bojo68's Avatar
I know that pulling the plug out of the back of the alternator will cause the fuel pump to stay on at all times the ign is on. That's a standard test for the fuel system on these.
Old Jul 17, 2009 | 10:38 AM
mikesz's Avatar
Wow i pulled the alternator plug out and back in and the fuel pump is priming for the 5 second period and turns off.The engine still won't idle.I have to keep my foot on the gas.
I did take it for a short drive and had full power.I don't know if the pump is bad or not.I was thinking maybe the inlet screen became clogged up all of a sudden or the fuel filter needs replaced.I'll probably get a new one anyway.
Old Jul 20, 2009 | 11:05 AM
mikesz's Avatar
Cleaned the inlet screen today and the car runs just fine now.
Old Jul 20, 2009 | 05:03 PM
by the pump? ..or in the tank? Where iz it?
Old Aug 17, 2009 | 08:43 PM
1SlowZX's Avatar
Yeah would like to know as well, mine seems unusually loud.. Almost as bad as my Sisters Chevy
Old Aug 17, 2009 | 09:50 PM
loud is normal for a 280zx
Old Aug 18, 2009 | 11:49 AM
1SlowZX's Avatar
At the risk of sounding stupid, i take it the 280zx runs an out-tank pump similar to old Chevys (90s), hence the loud noise. Or am i mistaken and it is an in-tank pump?
Old Aug 18, 2009 | 11:54 AM
Indeed. Inline (external) pump.
Old Sep 1, 2009 | 09:55 PM
RonAZ78Z's Avatar
fuel pump running
I had the same problem with the fuel pump running. It turn out to be a bad (shorted) alternator. The alternator died a few days later. A new alternator (remanufactured not rebuilt) took care of all problems. I don't know if this will help you but it worked for me.
r2doesinc
Nov 11, 2014 08:54 PM
sameerb1
Mar 20, 2011 05:21 AM
ern
Oct 20, 2006 07:01 AM
3XAZOWNER
Jun 6, 2006 08:05 PM
280ZXtreme
Apr 10, 2001 07:00 AM
