Fuel Problem
Old May 14, 2008 | 11:08 AM
iielmosglueii's Avatar
Fuel Problem
Okay so I haven't had any fuel problems before with the car. I drove the car in the dirt one day and next thing you know, after coming back from a friends house it decides not to start. I noticed the fuel not going through when you put the key in the on position. If anyone has any solutions to this that would be great, sorry if this is another repeat of a thread before but I just wanted to get this out before class. Looking forward to the responses, I'm eager to get the Z running again.
Old May 14, 2008 | 11:44 AM
Can you hear the fuel pump when you turn the key on?
Old May 16, 2008 | 06:03 PM
No, I don't. Usually I hear it though
Old May 16, 2008 | 06:26 PM
3XAZOWNER's Avatar
Mine did that once and i replaced the fuel pump, changed out the ignition switch, checked some fuse under the dash from my parts car, but got nothing. After about 3 hours of piddling, i called the guy who told me to check all this stuff, and he said "did you check the fuse link under the hood? You should have checked that first. That one I did not hear him say anything about. I popped the hood on my parts car and removed a metal panel from the fender wall beside the battery. Behind the metal panel was a wire that had a fuse link in it. It took less than 5 minutes to find the link, pull it and put it into my car and the fuel pump kicked in. So check power to the pump and check that fuse link before replacing pump or any other stuff i did. Learn from my mistake. Good Luck!
Old May 17, 2008 | 01:12 PM
is that for a 280zx? because I can't find the metal panel you are talking about.
Old May 17, 2008 | 02:51 PM
Where's your Haynes Manual??? Where's your SEARCH fingers?
https://www.zdriver.com/forums/showt...hlight=fusable
Old May 17, 2008 | 07:23 PM
3XAZOWNER's Avatar
Sorry, one of my panels is metal with a screw, but the one on my 83 is a plastic panel, right beside the fuse link in the photo towards the firewall. Remove the panel and the wires are actually in the fender wall. You just pull them out and switch out that fuse link. This may not be your problem, but it was mine and the easiest fix of all the things the mechanic i bought my car from told me to try. I like to start with the easiest and cheapest fix and work my way up, when i am troubleshooting. Good luck!
Old May 17, 2008 | 08:38 PM
yeah i figured it was that plastic panel, I didn't see anything wrong with the link but now since I have time I'll have a friend go through troubleshooting with me now. Oh for an update, I tried starting it again and no response what so ever.
Old May 18, 2008 | 06:57 PM
Maybe you could break out a multimeter (or even a 12v light bulb) and check for power at the fuel pump.
Old May 26, 2008 | 08:24 PM
Is there any way I can get pictures of that fuse link?
Old May 27, 2008 | 09:09 AM
Yep... it's called www.google.com Or crack open your dusty repair manual....
http://cgi.ebay.com/ebaymotors/Datsu...spagenameZWDVW
http://www.atlanticz.ca/zclub/techti...nks/index.html
Old May 27, 2008 | 11:10 PM
sigh, i knew i'd get flamed for askin aha thank u nismo
Old May 28, 2008 | 12:00 AM
That wasn't "flaming." It was a courteous nudge to search & find... and I still helped you.
Old Apr 17, 2009 | 02:27 AM
It was the fuel pump.
Old Apr 17, 2009 | 06:55 AM
w00t! Hopefully the car wasn't sitting all this time...
Old Apr 18, 2009 | 09:03 PM
pete8717's Avatar
My fuel pump won't do the pre start prime. I've changed all fuel pump relays, and every fusible link. The car will still start though. Maybe I have to change out the efi relay?
Old Apr 18, 2009 | 09:16 PM
Is yours a turbo?
Old Apr 19, 2009 | 10:02 PM
pete8717's Avatar
Nope. 1981 non turbo
Grizzlyadams17
Nov 7, 2013 03:10 PM
soates4
May 22, 2013 06:43 AM
rupert42
Aug 15, 2004 06:08 PM
MasonVonRitchie
Aug 3, 2004 04:10 PM
TmikeX
Apr 15, 2003 06:10 PM
