Fuel Problem
If you bypassed it, how did you do that?
That sensor changes ohms to the fuel injection computer based on the engine temperature. If you are bypassing it, you should run it through an ohm meter (simple volume control) and adjust it down more. That should get it to lean out more.
Also, check your fuel pressure if possible. I think it should be in the 40psi range. If its too high, then replace the fuel presure regulator. You can get those online for about $30 or so.
expressautoparts.com
How are the injectors themselves? If the they are getting old, the pintle might not be closing all the way during the "down" time of the injector and that could be soaking your plugs.... Just a thought.
John
John
Guest
Posts: n/a
mine did the same thing...
changing the sensor it helped mine, or you can put a potentiometer in and be able to control how rich or lean you run all the time. 1500 ohms 1.2K
here is the part # that i used....
OHMITE
2 WATT-TYPE AB POTENTIOMETER
MILL #-RV4LAYSA152A
CAT. NO. CLU-1521
IT WORKS GOOD.
OHMITE
MILL #-RV4LAYSA152A
CAT. NO. CLU-1521
IT WORKS GOOD.
ReVg30De
Jul 10, 2003 12:54 PM
