Coil Question
Old Jun 2, 2005 | 09:30 PM
280ZX_AV8R's Avatar
Coil Question
I'm New Here! I Have A 1982 Turbo 280zx And I Just Read Earlier That Reversing The Wires On The Coil Greatly Affects Performance. Well, I Looked And There Is A Black Wire And A Blue Wire. The Black Wire Was Hooked Up To The Positive Side And The Blue Wire To The Negative Side.
My First Instinct Is Black Is Always The Ground Wire (or Negative) So I Reversed Them Back. So Far I Can't Tell The Difference. The Car Feels Stronger, But It May Be My Imagination. So, Is The Black Wire To Be Put At The Positive Or Negative Side?
Old Jun 2, 2005 | 10:56 PM
Heat Rave R's Avatar
Um, just where did you hear reversing the coil wires was good for performance?
Old Jun 2, 2005 | 11:02 PM
280ZX_AV8R's Avatar
no I heard reversing them while changing out the coil was bad for it and this is a new coil and I think someone accidentally reversed them
Old Jun 2, 2005 | 11:03 PM
280ZX_AV8R's Avatar
in saying affecting performance I meant it does bad for it
not good.
Old Jun 2, 2005 | 11:04 PM
280ZX_AV8R's Avatar
Maybe I should say reversing the wires to the correct position would help it.
Old Jun 2, 2005 | 11:08 PM
280ZX_AV8R's Avatar
I just wanted to know if the blue wire was positive or negative
Old Jun 2, 2005 | 11:29 PM
280ZX_AV8R's Avatar
Someone please just type something! I feel like I'm talking to myself.
Old Jun 2, 2005 | 11:38 PM
assimilated420's Avatar
blue is negative.. mine is 81 turbo.. same design.. they put black/white stripe on positive and blue on negative..(weird huh..)
Old Jun 2, 2005 | 11:40 PM
280ZX_AV8R's Avatar
thanks, I guess I will have to switch it back in the morning.
Old Jun 3, 2005 | 12:14 AM
Haha, I just had the same problem with my '82 turbo recently (there's a thread on it still). I was installing a Crane ignition/coil and I forgot to note what color wire went to which coil. And the wiring is slightly different on my NA ZX, so that was no help. The "obvious" would be that the black wire goes to negative, but technically it's not black (black w/white stripe). So yeah, the black/white wire is positive.
Old Jun 3, 2005 | 01:16 PM
280ZX_AV8R's Avatar
I guess that shows I shouldn't mess with anything that I'm not sure about. I certainly thought the blackand white wire was negative, but I was wrong.
timo944
Mar 15, 2013 06:43 PM
IMSA RX300
Nov 23, 2011 08:31 AM
attacksoma
Dec 9, 2009 10:06 PM
frank280zx
Apr 9, 2007 09:07 AM
zphreak
Jul 8, 2002 05:30 PM
