car wont start
Old Oct 26, 2012 | 12:04 AM
wickedminded420's Avatar
car wont start
I had my car start for me the first time now it won't start it has spark is getting gas but won't fire and firing order is set correct 1-5-3-6-2-4 its a 82 280zx
Old Oct 28, 2012 | 11:52 AM
Welcome to ZDriver!
You're almost there...
An engine needs PROPER air, fuel, and spark to start.
Have you verified spark and fuel at all cylinders?
Old Oct 28, 2012 | 03:59 PM
rogerz's Avatar
Grumpy & Helpful
Clean the connectors for the maf or afm, ecu and tps. Deoxit by CAIG is probably the best connector cleaner on the market. spray with CorrosionX after cleaning and before putting together this will help prevent any further corrosion.
battery is the heart of your electrical system. if it isn't aone shape you got a problem
moorebl
Apr 14, 2011 03:28 PM
ZXT83
Oct 3, 2009 01:07 PM
dreamspawn
Dec 20, 2008 10:15 AM
JaYaYsSoHN
Dec 29, 2004 12:58 AM
rickyTT
Sep 26, 2004 06:11 PM
