280zxt no green light at ecu.
Old Jul 16, 2012 | 08:37 PM
rhythm's Avatar
Help, I have a 1983 280zxt "no start"...no spark,...no fuel..I have power to the dizzy(red wire),I have power to the coil (not 12v...more like 10/8)I brought the car as a no start..I don't see a green light in the ecu when the key is on..could i have the wrong ecu? my ecu # is..A18604046..my car is auto/turbo...help
Old Jul 16, 2012 | 09:03 PM
Welcome to ZDriver!
Start by checking the fusible links. If you haven't done so yet, download the FSM for free at XenonS130 - S130 Reference
Old Jul 19, 2012 | 02:15 PM
rhythm's Avatar
Thanks...for the info..(what are your thoughts on megasquirt?)...
Old Jul 19, 2012 | 03:53 PM
My thoughts are... it's good.
Did you fix the problem?
Old Jul 19, 2012 | 04:15 PM
rogerz's Avatar
Grumpy & Helpful
if you can't get an s130 running I think megasquirt might be a stretch.
Old Jul 19, 2012 | 08:34 PM
rhythm's Avatar
Question
not yet...thanks for the link..I'm on my way!!..this car was running when the previous took it to a shop...3 mos later..the car was towed home...the coil wires from the igniter was connected backwards,and the ecu was on the floor with several wires spliced..I changed cas,igniter,coil...nothing..so far...I'm checking for continuity from dizzy to ecu..then I read a post that said I should have a green light in ecu?..so now I'm checking ecu part #..and what causes a green light.
Old Jul 19, 2012 | 09:04 PM
rhythm's Avatar
No..not yet..this is new ground for me...I changed cas, Ignitor,and coil,I checked for conuity in wires that connect to cas from harness.(checks out good).now i plan to check from harness to ecu...still no spark,injector pulse,fuel pump or green light in ecu..if its the ecu I was thinking mega squirt instead of the stock ecu.
Old Jul 19, 2012 | 09:08 PM
rogerz's Avatar
Grumpy & Helpful
no green light no power to ecu. (highly unlikely the led burned out)
Old Jul 20, 2012 | 12:12 AM
borini63's Avatar
Start the car and rev it to 2000 RPM for 3-4 minutes then you will see the green light blinking!!!If you see it blinking then your ECU is working....this is the only way to see the green light.
If your car not starting then you will never see your green light.Time to trouble shoot and test!!
Old Jul 26, 2012 | 09:25 PM
rhythm's Avatar
Thanks Nismopick for the service manual link,...if it turns out to be the ecu...I'm leaning towards mega squirt...the fusible links are fine..how do I check the cas?
Dirt Winston
Mar 26, 2013 08:26 AM
joel280zt
Aug 2, 2012 06:10 AM
datsuns130
Jul 24, 2012 08:32 AM
stcrispin
Jul 25, 2005 06:58 PM
