280zxt no green light at ecu.
Help, I have a 1983 280zxt "no start"...no spark,...no fuel..I have power to the dizzy(red wire),I have power to the coil (not 12v...more like 10/8)I brought the car as a no start..I don't see a green light in the ecu when the key is on..could i have the wrong ecu? my ecu # is..A18604046..my car is auto/turbo...help
Welcome to ZDriver! :006:
Start by checking the fusible links. If you haven't done so yet, download the FSM for free at XenonS130 - S130 Reference |
Thanks...for the info..(what are your thoughts on megasquirt?)...
My thoughts are... it's good.
Did you fix the problem? |
if you can't get an s130 running I think megasquirt might be a stretch.
Originally Posted by rogerz
(Post 313749)
No..not yet..this is new ground for me...I changed cas, Ignitor,and coil,I checked for conuity in wires that connect to cas from harness.(checks out good).now i plan to check from harness to ecu...still no spark,injector pulse,fuel pump or green light in ecu..if its the ecu I was thinking mega squirt instead of the stock ecu.
no green light no power to ecu. (highly unlikely the led burned out)
Start the car and rev it to 2000 RPM for 3-4 minutes then you will see the green light blinking!!!If you see it blinking then your ECU is working....this is the only way to see the green light.
If your car not starting then you will never see your green light.Time to trouble shoot and test!! |
Thanks Nismopick for the service manual link,...if it turns out to be the ecu...I'm leaning towards mega squirt...the fusible links are fine..how do I check the cas?
