Rebuid Struts
Old Nov 18, 2005 | 12:49 PM
dolcevita09's Avatar
Cool Rebuid Struts
The 1983 280ZX Service Manual has a whole section on rebuilding struts. Is this something that is commonly done, or should they simply be replaced? Thanks for your opinions.
Old Nov 18, 2005 | 01:07 PM
You're talking about the front struts? cuz the rears are all one piece.
Front struts just have a cap that is unscrewed @ the top & the shock canister pulls out. You can also separate the ball joint from the strut (best done while still on the car).
Old Nov 19, 2005 | 05:05 PM
well, I think they are usually just replaced.
The fronts have what is called a strut 'insert'. and the rear, is a strut. Oh, some places call the rear a shock probably because the bottom end is held on with a bolt.
Old Nov 19, 2005 | 05:33 PM
RodMoyes's Avatar
Doesn't post much...
Rebuilding a strut would be like buying a used set of false teeth... it just ain't right. And yes, the rears are also struts but they are a differnt type than the front. The Z31 had shocks on the rear (outside the spring).
Rod.
mhough326
Oct 9, 2007 03:18 PM
r_willy
Jun 2, 2006 01:39 PM
Speed
Jan 4, 2004 07:57 AM
duckyz
Nov 8, 2003 06:20 PM
madhatter
Jun 14, 2003 06:56 AM
