Rear end hops at hard turn
Old Nov 8, 2005 | 01:11 PM
DarrellBuddy321's Avatar
When i take a hard turn the rear of my car hops? I dont know why? My friend with an s13 said that his did that and got solid rear subframe spacers. I have a 79 280zx, even if i wanted to whip my tail out at a turn it hops rather than slides any advice guys?>
i have
tociko struts and springs
energy suspension bushings
suspension techniques sway bars
front strut bar
Old Nov 9, 2005 | 11:27 PM
can anyone?
Old Nov 9, 2005 | 11:34 PM
apollo's Avatar
Pro Pumpkin Carver
Maybe your LSD is locking up? sounds like the diff to me
Old Nov 10, 2005 | 06:57 AM
indeed.... sounds like what happens when you weld up the spider gears in the diff. If you still have an open diff, it might be something loose or catching in the suspension.... maybe locked up brake caliper??? "Gets on unduh thur n check et oout!"
Old Nov 10, 2005 | 11:27 AM
RodMoyes's Avatar
Doesn't post much...
A '79 doesn't have an LSD unless you put one in it...
It could be a problem with the diff though still.
Sounds like you have a good suspension set up going but how's the rear camber?
Excessive negative camber can cause this.
Also check the mounts on the diff. If they are smoked, the whole assembly is going to rock back and forth under a load... No bueno.
Rod.
Old Nov 17, 2005 | 02:35 PM
apollo's Avatar
Pro Pumpkin Carver
You finished the LSD swap didnt you?
Old Nov 21, 2005 | 09:05 PM
i found my problem...DAMN BLOWN STRUT! Only 1 year old tokico hp and its blown...
Old Dec 20, 2005 | 09:00 PM
jmmorriso's Avatar
I was gonna say bound up bushing, but you got it!
315driver
Jul 10, 2012 08:25 PM
pmf123
350Z Brakes, Wheels, Suspension and Chassis
May 21, 2007 02:03 PM
juggalo280ZX
May 6, 2005 08:03 AM
oldschool
Apr 25, 2005 06:36 AM
CHSTigersFan
Sep 28, 2004 09:48 PM
