half shaft upgrade??
Old 11-30-2012, 07:22 PM
silverzxbullet's Avatar
Ok ive been searching with both the search function and browsing through pages with no luck. In my countless hrs on here reading and reading I thought i remembered coming across a thread on upgrading the the rear half shafts for the diff with a cv axle set up... off of a turbo car??
Can someone guide me to that tread.. since im no longer commuting in my 83zx ive been just playing with it and thinking about taking my spare diff and welding it just to have a lil more ease with sliding it around but threads talking about that say they have a tendency to blow the half shaft out.. thanks guys.
silverzxbullet is offline
Old 12-01-2012, 08:06 AM
zenzee's Avatar
Half shafts breaking with welded diff
I have a set of CV's if interested. And yes more power to the rear wheels will have to match up to CV's. Today i will not be at the computer, so you may contact me on my cell 209-380-9719.
zenzee is offline
Old 12-01-2012, 10:51 AM
Grumpy & Helpful
rogerz's Avatar
you need the parts that match up to the half shaft and the stub axle. Just the half shaft won't do it.
rogerz is offline
Old 12-01-2012, 01:45 PM
Sent a text guess ur busy or cnt get text.. definitely interested tho. Where abouts in the 209 are u? Im in the stockton area.
Im looking to go from half shafts to a cv set up..
What yr model is the cv set up from? So i can look it up in the fsm.
Thanks all
Old 12-02-2012, 08:00 AM
I would get the whole rear subframe. The geometry is also apparently improved as well on the turbo cars. Once you have the whole sub frame you can rebuild the whole rear end out of the car if you want.
And yes the CV rear end is from the turbo cars. I've heard rumours of the turbo rear end setup being found in some later 280ZXs but I've never seen it.
FricFrac is offline
Old 12-02-2012, 09:17 AM
zenzee's Avatar
CV shafts upgrade
Thanks all
I'm in Salida border Modesto. E/mail a contact number and i'll call you to see the parts i have.
zenzee is offline
Old 12-02-2012, 12:45 PM
Grumpy & Helpful
rogerz's Avatar
cv setup was also in some (maybe all) of the 2+2 - Not sure on that my memory is that i saw one in the junkyard that I was pulling parts from.
rogerz is offline
Old 11-19-2018, 06:56 PM
BlackS130's Avatar
Is this true as far as the geometry is improved? where is the improvement made?
RT
BlackS130 is offline
garretthes
05-01-2012 09:36 PM
FubarI33t
01-02-2009 04:16 PM
OlderThanMe
05-02-2005 01:24 PM
81 Black L28E
01-28-2005 05:24 PM
jvanen
07-21-2003 09:12 AM
Quick Reply: half shaft upgrade??
