u-joint help needed
Old Feb 23, 2005 | 08:49 PM
theramz's Avatar
I have a present for you...
The half shafts consist of a male and female spline that slide in and out. They don't usually wear out. If they are, you will half to try and find some in the junk yards. If the boots are torn, you should replace them at this time.
Old Feb 28, 2005 | 02:11 PM
ZCurves's Avatar
You can order new boots for the Half Shafts from Victoria British for +/- $20. U-Joints are probably another $20-$40. If you are familiar with changing U-Joints then you can handle the Half Shafts. As for the Drive Shaft. Nissan pressed the originals in and Splined the lip, thus making them "throw-away". I took my Drive Shaft to a Drive Shaft shop and they replaced my U-Joints and Balanced the Shaft for $100. Now everything is smooth and tight.
zerodisorder
Jul 22, 2010 09:10 PM
TeamRonin
Jun 21, 2009 10:37 AM
jamesfraZier4
Dec 18, 2007 08:17 PM
motoxracing909
Jan 25, 2006 11:55 AM
droc217
Feb 3, 2005 08:26 PM
