hey guys im new any thoughts
Old Apr 12, 2008 | 10:02 AM
  #26
Mhinrichs's Avatar
Mr. Fancy Connectors
My 3 suggestions (in no particular order):
#1... Restore the car. The rust isn't all that bad... I've seen a lot worse.
#2... Pull the motor & swap it into a convertible S13 240sx... then you can have the best of both worlds.
#3... Part out the car & sell me the cylinder head.
I thought you where buying my cylinder head.....
Old Apr 12, 2008 | 02:19 PM
  #27
mudtoy1986's Avatar
well the rust and all isnt all that bad everyone around me thinks im crazy and all for wanting to fix it till they see that its a turbo
but its my 1st z car and i plan to fix it when i get the new floors and subrame parts it wont take me more than a month to get it one the road
thankfully its where i work so i have acces to everything i need for tools
Old Apr 12, 2008 | 03:13 PM
  #28
so what exactly do you do? and where are you located?
Old Apr 12, 2008 | 03:16 PM
  #29
mudtoy1986's Avatar
well i work in a junk yard and i live in va the reason the car went to the junk yard was due to the rust
and we also have a full body shop located where i work
Old Apr 12, 2008 | 06:18 PM
  #30
i didnt know people worked at junkyards. i thought it was just owned. lol.
Old Apr 12, 2008 | 08:03 PM
  #31
lww's Avatar
lww
Head Muckraker
Dude, in large metropolitan junk yards, they employ dozens and sometimes hundreds of people.
Old Apr 12, 2008 | 08:23 PM
  #32
Indeed I am... but one can never have too many turbo cylinder heads.
Old Apr 13, 2008 | 01:40 AM
  #33
Mhinrichs's Avatar
this is true... maybe i will keep mine...
Old Apr 13, 2008 | 01:42 AM
  #34
turbo head are over rated. N42 is where its at. i gots me 2 of dem!
Old Apr 13, 2008 | 01:47 AM
  #35
Don't be like that! I was counting on yours to get my Z back on the road.
Old Apr 13, 2008 | 01:49 AM
  #36
Mhinrichs's Avatar
In that case i`ll pull it next weekend..... will be the soonest I am able.
Old Apr 13, 2008 | 04:58 AM
  #37
mudtoy1986's Avatar
lol you didnt know people worked at junkyards been workin in junk for about 10 or 11 yrs
Old Apr 13, 2008 | 05:01 AM
  #38
mudtoy1986's Avatar
well dont think ill be selling my head jut yet i plan on keeping my car as original as i can
Old Apr 13, 2008 | 03:05 PM
  #39
mudtoy1986's Avatar
hey got a new prob with the car dont run no more
1st checked the fuel pump and changed it
still no fuel pressure so i went to the sending unit was compleatly cloged with sludge
so i changed it i also saw what looks like a pressure regulator but its got a bolt with a nut on it is that an adjustable pressure regulator?
i need help maybe some one has asked this question before i dunno
Old Apr 13, 2008 | 03:12 PM
  #40
Mhinrichs's Avatar
seafoam my friend. learn it live it. Try removing the fuel rail, pump, injectors, regulator as a whole, then mix a can of seafoam with five gallons of fuel and run that through, repeat until clean, also get a clip for the injectors and add some wires so you can use a 12v power supply to open them while running seafoam.
Old Apr 13, 2008 | 04:06 PM
  #41
mudtoy1986's Avatar
so put constant power to the injectors? seafoam ive hear that stuff was pretty good
Old Apr 13, 2008 | 04:07 PM
  #42
mudtoy1986's Avatar
oh and can i ad seafoam to the tank for everyday use?
Old Apr 13, 2008 | 04:39 PM
  #43
Mhinrichs's Avatar
yes you can, and you only need to trip the injectors.
Old Apr 13, 2008 | 04:47 PM
  #44
mudtoy1986's Avatar
ok thanks man ill try anthing to get this thing running again so i can start the rust removal
Old Apr 14, 2008 | 04:20 PM
  #45
mudtoy1986's Avatar
got it running again i had to force feed it till it would idle again
back on the body work i had fould out plugs but ill be usin the seafoam this weekend as well as about 10 gallons of fresh fuel thanks for the help
Old Apr 14, 2008 | 05:01 PM
  #46
KasbeKZ's Avatar
Pr0n Addict
where in VA? what junk yard? (not to say i know all of them. i only use chesterfield. or did when i had a honduh at least)
Old Apr 14, 2008 | 05:04 PM
  #47
mudtoy1986's Avatar
jr's used auto used to be roberts its chesapeake on us 58
  #48
mudtoy1986's Avatar
why do ya ask?
Old Apr 14, 2008 | 05:17 PM
  #49
KasbeKZ's Avatar
Pr0n Addict
cause i live in va. wondering if i would see that car around. i live a bit north. i'm directly east of richmond. in middlesex (no joke). it's the west point exit off of 64
Old Apr 14, 2008 | 05:27 PM
  #50
mudtoy1986's Avatar
well hopefully by september ill have it on the road in the prosses of restoring it
