ok I cant find this sensor... do yall know?
Old Dec 31, 2008 | 05:21 PM
bmwe30's Avatar
the coolent temp sensor with the huge bolt on my 280z died,
thus causing the motor to run extremly rich,
I went to autozone, advance auto, and an independent auto store in my town
all of them gave me the wrong sensor,
I also checked rock auto but nothing... any idea where to get it?
I think I found it, would it be a Water Temperature Sensor, 75-79 Z/ZX?
found on the Z store
it doesnt have a picture so I dont know for sure
Old Dec 31, 2008 | 06:32 PM
http://www.courtesyparts.com/engine-...ath=7002_7767&
Same thing as the CHTS... which you CAN one at your local parts store, if you tell them the right item.
http://www.courtesyparts.com/water-t...ath=7002_7767&
Old Dec 31, 2008 | 07:33 PM
bmwe30's Avatar
are you sure thats the right part? the one off of the motor has a huge bolt...
did they just down size the bolt? we'll see
what is the correct term?
Old Dec 31, 2008 | 07:36 PM
bmwe30's Avatar
also that is for a zx, woundnt that be different?
Old Dec 31, 2008 | 07:54 PM
How about posting a picture of this "huge bolt" cuz I have no idea what you are talking about.
Old Jan 1, 2009 | 01:38 PM
bmwe30's Avatar
ok will do, the shop that my car is at is closed right now,
I'll post it tomorrow
Old Jan 1, 2009 | 03:47 PM
theres only 2 sensors for the coolant in a S30 as far as i know one for the warm up procedure the other for the temp gauge i do believe and they are all up by the thermostat neck. it wont make the car run richer unless the secondary injector in the TB is staying activated.... i cant think of the proper term for what it is but yeah you can just unplug it, temperature doesn't effect anything else on the S30 other than those things im fairly sure
Old Jan 1, 2009 | 05:41 PM
bmwe30's Avatar
well there are three sensors on the front of the motor in the same general area, I'll be up there tomorrow to figure it out some more,
I have had two people tell me the same thing about the same sensor, so my money is on the sensor
Old Jan 1, 2009 | 06:23 PM
well really, the S30 system is very simple and how do you know its running so rich out of curiosity? there's not many sensors on the S30 so if its running REALLY rich it might be more than just a bum temp sensor though you should replace it anyways obviously.
Old Jan 1, 2009 | 06:53 PM
bmwe30's Avatar
well gas is coming out the tail pipe, it burned 1/2 tank in under 6 miles, and the spark plugs have gas on them, it's firing on less then 6 by far, I checked each plug (which are brand new) for spark,
also I have a trusted opinion of a master michanic,
from what I understand that sensor detects the temp of the engine via coolent, when it's cold it tells the computer to run rich to get the motor warmed up, I beleive acting like a choke
so the sensor is dead and the computer thinks the motor is very cold all the time so it runs very rich all the time
Old Jan 1, 2009 | 07:01 PM
it doesn't effect the normal injectors there's a secondary injector in the manifold itself that is used during warmup. also, it doesn't make it run THAT rich so if theres gas coming out of the tailpipe you got something else up, also half a tank in 6 miles, i don't think either of those two are even possible and the engine still runs.
Old Jan 1, 2009 | 07:15 PM
^^^ Anything is possible, but I agree... engines can only run SO rich. Dumping raw fuel out the tailpipe would be hard to do and keep it running.
Old Jan 1, 2009 | 09:43 PM
bmwe30's Avatar
I could keep it up to 35 mph, studdering like hell, but when at full throttle at around 4000 rpm it would take off like usual, but only at full throttle and only at that high rpm,
after a while it wouldnt start anymore, because of all the gas
Old Jan 1, 2009 | 10:03 PM
seabee280z's Avatar
man i had the same problem and it ending up being my thermotime sensor.
Old Jan 2, 2009 | 08:22 AM
bmwe30's Avatar
where can I find one of these? I called my local parts stores they never heard of it
Old Jan 2, 2009 | 08:37 AM
google pwns again:
http://frugalmechanic.com/auto-parts...mo-time-switch
http://www.autopartsfair.com/nissan-...em-321297.html
http://www.classiczcars.com/forums/s...ad.php?t=31895
http://www.jcwhitney.com/BOSCH-THERM...2049_10101.jcw
Old Jan 2, 2009 | 10:41 PM
bmwe30's Avatar
ok great news, I fixed it
Old Jan 2, 2009 | 10:43 PM
bmwe30's Avatar
I didnt know untill just then that it was called a thermo time sensor, and it ended up being the coolent sensor that was bad,
Old Jan 3, 2009 | 08:33 AM
Whew... that was an ordeal.
Old Jan 3, 2009 | 11:10 AM
bmwe30's Avatar
well to me it was cause I had to get to work like an hour before I fixed it haha
thanks for the help yall
ooharloo
350Z Brakes, Wheels, Suspension and Chassis
14
May 2, 2014 06:24 AM
nick731
May 8, 2012 07:38 AM
nismo619
May 17, 2010 10:52 AM
nismo619
Sep 8, 2008 09:34 PM
saaddaa7
Aug 5, 2003 09:37 PM
