Motor won't turn over
Old Oct 5, 2003 | 01:39 AM
icice9's Avatar
Super Siver & Black Stud
test to see if its your starter... try to remote start the car.. the ticking noise could also be your solinoid clicking..... put your car in neutral and the kep to on... then on your solinoid job the positive terminal to the switch terminal and see if the car turins over.. if it does then its your relay... if it dont... its your starter...
Old Oct 5, 2003 | 08:19 AM
Creator's Avatar
uh, do you have a simple wiring diagram of which side is positive on that silinoid, my z is doing the *EXACT* same thing (it wasnt turning over, i replaced the starter last week, i got it to turn over once on the new starter, no the 3post silinoid is clicking (my interior access. work fine too). I'm looking for a replacement silinoid now, but if someone can tell me which is the positive post (or which ones i need to connect to make sure) that would be great.
Thanks.
Old Oct 5, 2003 | 02:19 PM
icice9's Avatar
the pos. terminal is the one that directly connected to your pos side of your bat.. jsut follow the pos wire to the starter.. and thats where its at... if your looking at your starter from the top.. its the terminal at the bery top of the solinoid.. the ignition terminal is the lil clip on the side of it... if you get a wire and jump those 2 terminals.. the starter should crank over... ut remember to have your car in neutral.. dont want you Z to buck on you when you do this... lol
Old Oct 7, 2003 | 05:26 AM
Creator's Avatar
seerexracing, errr, where was the problem??? Just so i can double check mine.
thanks
.cre
Old Oct 8, 2003 | 03:42 PM
z_lis's Avatar
This is a little off the subject, but can any of you tell me how I can put the picture of my car
in the little pace on the left my my name?
davidjoe007
Jun 29, 2021 04:45 PM
theramz
Dec 3, 2007 02:43 PM
81s280zx
14
Oct 7, 2005 10:48 AM
juggalo280ZX
May 6, 2005 08:03 AM
orngxtc
Aug 13, 2001 01:08 PM
