Okay, my turn for help
Old Dec 2, 2007 | 10:01 PM
theramz's Avatar
I have a present for you...
I have a '77 that I bought from another member. It has a completely rebuilt engine. It was all apart when I got it. Now I can't get it to start. Got everything to work except the injectors. Is there a relay to the ECU? I've got fuel pressure and spark. Even the cold start injector won't squirt.
Old Dec 3, 2007 | 07:49 AM
turboZ87.300's Avatar
ECU could be bad... or no power going to the ECU that runs the injectors... or the pick up sensor??? You need to check all the wires, make sure that it's good... good luck...
Old Dec 3, 2007 | 08:42 AM
the FI system does have a relay. should be the only one under the hood thats out in the open, just a square 4 pin (i think) relay plug.
Old Dec 3, 2007 | 11:52 AM
BoulderZ's Avatar
Have you already done the noid light test to see if there's a signal to the injectors? Even newly cleaned, if the injectors have sat for awhile, they might all be stuck. That was the case with mine when I first fired it up after the rebuild. Just a thought.
Dave
Old Dec 3, 2007 | 02:06 PM
theramz's Avatar
I found some good info at Alanticzcarclub. The relay is under the dash. Now I can hunt the problem down I hope. Since it was a runnig car before tear-down I think it's a wire I overlooked. I will let you know. Thanks guys!
Old Dec 3, 2007 | 02:43 PM
haha..... maybe it is under the dash, i forgot I MOUNTED mine in the engine comp when i did my turbo swap. lol. put a hand on the relay give the key a turn to ON and you should feel it kick.
vJimmyv
Jan 21, 2013 02:17 PM
dntbther
Sep 5, 2011 12:54 PM
juggalo280ZX
May 6, 2005 08:03 AM
seerexracing
Oct 8, 2003 03:42 PM
orngxtc
Aug 13, 2001 01:08 PM
