I think its New clutch Time
Old Aug 2, 2007 | 06:55 AM
Texizgreat's Avatar
I have an awful loud squeal when I am in gear after the 280z warms up a bit. My mechanic buddy said it sounds like the release bearing....
So while we are in there I am just going to replace the whole clutch. My question is what do these mean when looking up clutch parts...
Clutch 1. 9-1/2 X 1 X 24T SPLINE
Clutch 2. (napa) 8 7/8"-24-1"
Clutch 3. (napa) 225mm Splines:24
Thanks
Old Aug 2, 2007 | 07:28 AM
theramz's Avatar
I have a present for you...
Those are clutch referance sizes. #1 is 240mm for ZX cars. #2and #3 are the same, 225mm = 8 7/8 diameter. All are 24 spline. Your stock 280z has 8 7/8 dia.
Old Aug 2, 2007 | 08:07 AM
Texizgreat's Avatar
thank you
Should i go with what is labled "proformance" ?
Old Aug 2, 2007 | 09:08 AM
260zturbo's Avatar
Stupid Hurricanes...
240mm came in 2+2 (z and zx) and turbo cars. performance unless you have performance engine. other wise a stock clutch will be fine. i have a 6 puck in my z with goodies. the 6 puck is a little hard at first but once use to can be fun. make sure u bleed you clutch system again. go ahead and check you slave to see if it needs replacing as well as master. just cheap insurance.
Old Aug 2, 2007 | 12:00 PM
theramz's Avatar
That's right but you will also need the flywheel for the 240mm. A six puck is for racing with a robust drive train and suspension. It will break a oem drive line.
Old Aug 2, 2007 | 12:17 PM
Texizgreat's Avatar
and stock Napa parts it is.................
i found out that even stock can break the oem driveline. well, the tranny anyways.
Old Aug 2, 2007 | 12:24 PM
260zturbo's Avatar
what happens when you use OLD stock parts
Old Aug 2, 2007 | 02:01 PM
theramz's Avatar
You can get a Center Force clutch kit on ebay, it includes the alignment tool. As long as you don't side step the clutch you won't break anything!
Old Aug 2, 2007 | 03:25 PM
it only had 118k on it! and was owned by a hippie woman. definatly didnt get beat on. lol
Old Aug 4, 2007 | 08:58 PM
Texizgreat's Avatar
OK I dont think it is the Release Bearing!
Reason why is that after it warms up even in neutral when i rev it up it still squeals. Most likley just the belts.
Thank goodness. $30.00 vs. $200.00 is much better.
Old Aug 4, 2007 | 09:04 PM
Maybe next time you hear a weird noise you should just walk around the car & listen... the clutch & belts aren't too close to each other & you should be able to distinguish where the noise is coming from.
Old Aug 4, 2007 | 10:14 PM
Texizgreat's Avatar
Well when you buy a 30 y/o car you just expect the worst....
I find being a pessimist works out for the best.
Either I am always right or pleasantly surprised.
r2doesinc
Nov 13, 2014 03:27 PM
duckyz
Oct 28, 2010 11:48 PM
MetalTear17
May 4, 2004 08:09 PM
blkthghts
Oct 27, 2003 02:51 AM
