I think its New clutch Time
I have an awful loud squeal when I am in gear after the 280z warms up a bit. My mechanic buddy said it sounds like the release bearing....
So while we are in there I am just going to replace the whole clutch. My question is what do these mean when looking up clutch parts...
Clutch 1. 9-1/2 X 1 X 24T SPLINE
Clutch 2. (napa) 8 7/8"-24-1"
Clutch 3. (napa) 225mm Splines:24
Thanks
Thanks
240mm came in 2+2 (z and zx) and turbo cars. performance unless you have performance engine. other wise a stock clutch will be fine. i have a 6 puck in my z with goodies. the 6 puck is a little hard at first but once use to can be fun. make sure u bleed you clutch system again. go ahead and check you slave to see if it needs replacing as well as master. just cheap insurance.
Originally Posted by theramz
That's right but you will also need the flywheel for the 240mm. A six puck is for racing with a robust drive train and suspension. It will break a oem drive line.
and stock Napa parts it is.................
OK I dont think it is the Release Bearing!
Reason why is that after it warms up even in neutral when i rev it up it still squeals. Most likley just the belts.
Thank goodness. $30.00 vs. $200.00 is much better.
Maybe next time you hear a weird noise you should just walk around the car & listen... the clutch & belts aren't too close to each other & you should be able to distinguish where the noise is coming from.
r2doesinc
Nov 13, 2014 03:27 PM
