Head question
Old Oct 8, 2003 | 10:11 AM
Adz260's Avatar
Head question
What is so good about an e 31 head. also are e 88 heads good?
Old Oct 10, 2003 | 07:45 AM
preith's Avatar
Most people like it just for its small combustion chamber, which of course gives you a higher compresion. I think its kind of over rated. Unless your running an L24, an L28 w/flat tops with the E31 will give you about 11.5:1 compression. Too much for pump gas.
Personally, I'm a die hard N42 fan. With this head, you still have the square exhaust ports, and it already has steel valve seats. Sure the chambers are a little larger, but with flat tops you'll have about 10:1, perfect for pump gas. I'm just working off my memory, so I may be off a bit.
Old Oct 14, 2003 | 08:39 PM
theramz's Avatar
I have a present for you...
A great place to find out about the L series heads and their compression ratios is at the ZCARHOMEPAGE
Remington115
Sep 26, 2012 07:07 AM
ZZzzz
Sep 3, 2012 10:43 PM
rjc280z
Sep 24, 2009 06:39 PM
283zxt
Aug 1, 2004 07:50 PM
Meakin
Oct 25, 2001 12:41 AM
