All sorts of problems?
Old Aug 9, 2001 | 03:17 PM
rusty's Avatar
Re: All sorts of problems?
Check your dimmer switch after you test the fuse(s). My dash lights didn't work because the switch was fried. You can by pass the switch fairly easy. Losen up the center vent control portion of your dash (it makes it easier to see the switch and the wires). Simply unplug the wires leading to the switch and connect them together.
As far as the speedometer goes, check the connection to the transmission and confirm the cable isn't broken and actually connected. Not sure beyond that.
Make sure your exhaust is flowing freely. A clogged or restricted CAT can get real hot.
Hope this helps.
ZBspires
Aug 30, 2013 07:33 AM
86z31
Aug 16, 2010 06:14 PM
turbo84z
Jan 21, 2008 02:26 PM
k-link
Jun 13, 2005 09:39 AM
hondahunter
Mar 18, 2003 02:45 AM
