280z wont start when cold
Old Jan 26, 2009 | 07:04 PM
Laxguy's Avatar
i have a 1978 280z i have restored it to working condition. it normally runs great, but it wont start in the cold. once it warms it it starts up first try. should i look at the cold start valve or the temperature sensor?
Old Jan 26, 2009 | 07:15 PM
Welcome to ZDriver!
Yes yes... cold start valve is first on the list. Remove & clean. You can also flip it upside down on the fuel hose and test for spray.
If that doesn't fix the prob, check fuel pressure / fuel pressure regulator, spark plugs, wires, coil, etc. Make sure the plugs are gap'd to the correct spec.
Old Jan 28, 2009 | 11:07 AM
Laxguy's Avatar
hey, i checked for spray from my cold start valve and i got like a drop of fuel how do i clean it? or should i just replace it?
Old Jan 28, 2009 | 11:17 AM
Brake cleaner, a scotch brite pad, and a needle.
Old Jan 30, 2009 | 10:44 AM
Laxguy's Avatar
i cleaned my cold start valve and went to check to make sure i was getting spray, but now im not getting fuel to the valve. i know i have fuel preasure at the fuel rail because it starts fine when its warm what should i check next?
Old Jan 30, 2009 | 11:06 AM
Did you remove the valve from the rail / fuel hose to check for fuel?
Old Mar 7, 2009 | 02:09 PM
Laxguy's Avatar
i waited a bit then tried again and it started rtight up and i havent had a problem with that since thanks
76280z
Aug 9, 2017 03:40 AM
hootie233
Feb 17, 2012 02:34 PM
TonyD11
May 31, 2007 06:28 PM
rchrd989
Jan 12, 2006 01:28 PM
280zinkansas
Apr 17, 2004 03:54 PM
