Want to start so bad...
Old May 18, 2011 | 11:11 PM
76 2+2's Avatar
I have a 76' 280z 2+2 that i can not get to fire up... Completely lost my only thoughts of the problems is the fuel injection relay or the fuel pump... only thing is that i cannot test the relay and have know means of getting it done professionally.. please help i bought this baby for a $110.00 to prove a point that i can do this and with only 43k miles im basically questioning the ratio of faulty parts list above thank you in advance
Old May 19, 2011 | 07:45 AM
Welcome to ZDriver!
A motor needs 3 things to start:
-Proper air
-Proper fuel
-Proper spark
Does it have fuel pressure? Does it have spark?
Old May 19, 2011 | 02:48 PM
76 2+2's Avatar
i have spark and im not sure about the pressure but i doubt there is any...the 280 doen't start even if i run fuel almost directly to the injectors consistantly so could the fuel injection be to blame? But thank you for your help
Old May 19, 2011 | 07:06 PM
So pull the spark plugs to see if they are wet w/ fuel. If not, then no fuel pressure... check the ecu, connection, and power wires (aka fusible links).
Old May 21, 2011 | 02:02 PM
76 2+2's Avatar
Okay cool that will be my task for tomorrow and ill post results thank you for your help
Old May 25, 2011 | 02:26 PM
76 2+2's Avatar
How do i check the ecu?
zcooks
Apr 11, 2016 06:36 AM
bongpogi
Aug 19, 2015 11:15 AM
moorebl
Apr 14, 2011 03:28 PM
bardabe
Sep 21, 2004 03:12 PM
