transmission
Old 01-05-2009, 07:29 AM
Zphillips's Avatar
Talking transmission
Does anyone know what year datsun truck tranny w/5 speed will work w/my 1978 280Z 5 speed. I herd that it has longer legs for nice highway SPEED!!!
Zphillips is offline
Old 01-05-2009, 07:50 AM
Why not just get a lower ratio differential?
NismoPick is offline
Old 01-05-2009, 02:22 PM
Stupid Hurricanes...
260zturbo's Avatar
are you looking for direct bolt up? bc most datsun trucks come with a early version of a ka engine. or you can find a 2wd vg pathfinder i belive (beefy sx transmission with z32 guts). always have the sx tranny or z32 tranny. but most of these transmissions will require work. so either find a s130 5 speed or swap in a different diff as nismo said. the s30 5th gear is 0.684 zx 5th gear ratio 0.745 the sx 5th gear is 0.759 and finally the z32 5th gear is 0.752
260zturbo is offline
Old 01-05-2009, 03:57 PM
I have a present for you...
theramz's Avatar
The difference between all those trannys is only about 50 rpm at 65 mph. The biggest gain would be with the diff change. It takes more power to turn bigger ratios, so the gain is not much, maybe 300 rpm depending on what you have now.
theramz is offline
Flacster
10-20-2010 07:34 PM
zfreak1981
02-02-2010 07:20 PM
JDsmash
12-22-2006 07:00 PM
TAdam2000
11-23-2002 11:18 PM
BadfishZ
10-08-2002 04:40 AM
Quick Reply: transmission
