Spring Question
Old Dec 2, 2013 | 06:50 PM
ZChief's Avatar
Spring Question
I am running stock springs (old from 1970) on basically a rebuilt stock suspension that I've loaded with KYB gas struts and a urethane bushing kit. I have 225 x 60 x 14" tires that rub in the rear quite a bit when I hit the right bump and have 2 people in the car. I do not have the tire rub issue when only 1 person is in the car.
Would new springs help with a tire rub issue or are the tires just too big?
The second part of the question is if it is a spring issue, my thought is to go back with OEM springs because lowering the car does not seem to make sense if I'm already rubbing. Regarding OEM springs, I only see the fronts available new through Black Dragon.
Any suggestions and insight would be appreciated.
Old Dec 2, 2013 | 09:12 PM
What are the wheels "rubbing" against? Wheel well? Lip? Springs? Zero offset wheels?
Old Dec 3, 2013 | 07:35 AM
ZChief's Avatar
Spring Question
The tires are hitting the lip of the quarter panels.
zordietrying
Oct 26, 2010 11:01 AM
EZDUZIT
Jul 24, 2008 03:01 PM
6894kevin
Apr 28, 2008 12:00 PM
Turbo86
Mar 19, 2007 07:26 PM
RPS13_GZ32
Mar 21, 2006 10:54 PM
