Removing Fuel Sending Unit
Old Aug 24, 2008 | 06:39 PM
at-jefft's Avatar
Uber n00b!
I am trying to remove the fuel sending unit/fuel sender and I am having trouble figuring out how to go about this. The fsm is not very helpful and says to use a screwdriver. What tool/method is best to turn the retaining disc? Thanks, Jeff
Old Aug 24, 2008 | 07:50 PM
Yep... flathead & a mallet.
Old Aug 24, 2008 | 08:00 PM
at-jefft's Avatar
Uber n00b!
where do I place the flat head? the bent tab or the flat one?
Old Aug 24, 2008 | 08:59 PM
Place the flathead on the base of a tab. Here's a pic (not of a Datsun... but you should get the idea):
Old Aug 24, 2008 | 09:04 PM
at-jefft's Avatar
Uber n00b!
Wow. Thanks a ton. I was not expecting to get a pic.
Old Aug 25, 2008 | 02:02 PM
at-jefft's Avatar
Uber n00b!
Alright, I got it out. But the float looks good. it moves freely and there is contact with the wire coil throughout.
Is there any way to test it?
Also the reason I pulled it was because the gauge would not go to empty(around a 1/4 was lowest) when the car was running. Also it would only go to about 5/8ths when the tank was full. Could it be the gauge?
Old Aug 25, 2008 | 06:33 PM
ASA240z's Avatar
ダットサンマニアック
might be, you could get one on ebay for like $10 bucks. Wouldn't hurt the pocket too much to test out.
Old Aug 25, 2008 | 06:42 PM
at-jefft's Avatar
Uber n00b!
Ya sounds like a good plan. How much time/effort would it take to install the gauge? Would I have to pull the dash? Thanks, Jeff
Old Aug 25, 2008 | 11:00 PM
ASA240z's Avatar
ダットサンマニアック
it shouldn't be to hard to remove the gauge. my old glove box has a hole on the side so I was able to take the gauges out from there. Just make sure you disconnect the battery when you remove the gas gauge cause its also part of the amp gauge LIVE CURRENT, Thats the trickiest gauge to get out because the amp meter has these two weired connections. Other then that you shouldn't have a major problem. Ohh, I recommend that you use a magnetic screwdriver unscrew the gauges out to prevent from losing any of the bolts behind the dash. That can be a pain in the Azz.
Old Aug 25, 2008 | 11:17 PM
at-jefft's Avatar
Uber n00b!
alright short of putting a hole in my glove box how should I get at the gauges?
houlis1211
Feb 24, 2013 07:04 PM
HexaggramJDM
Jun 29, 2011 10:37 PM
rjc280z
Sep 29, 2009 01:13 PM
Carl's Z
Sep 12, 2005 04:53 PM
ratedZ
May 26, 2001 07:58 PM
