help please! 280z wont start
Old May 30, 2007 | 06:30 PM
TonyD11's Avatar
When i turn the key to the on position none of the electronics come on. The car wont turn over, the headlights turn on and thats it. I checked the fuse links and the fuses and they were all good, i replaced the ignition switch, the car will not even turn on. What is wrong with my car???
Old May 30, 2007 | 07:30 PM
flightforlife07's Avatar
did you check your body/chasis and motor ground?
Old May 30, 2007 | 07:39 PM
I suggest tracing the power in the + wires from the battery... Check for power @ the main fusable links, fuse block, and various accessories until you no longer get power. You can use a multi-meter or a 12v car lightbulb.
Old May 30, 2007 | 09:36 PM
hmm i jsut suggested body grounds cuz thats wut my car does some times my body ground comes loose and it does the same stuff you're prolly right tho nismo!
Old May 31, 2007 | 06:28 PM
TonyD11's Avatar
well we traced it all the way back to right before the ignition switch but we couldnt figure out where it was stopping, so we just re-routed the power wire from somewhere in the line that was getting power and put it directly to the switch, a temporary fix but at least i can drive my car. thanks for the help
76280z
Aug 9, 2017 03:40 AM
jeffj2689
Feb 24, 2006 01:55 PM
rchrd989
Jan 12, 2006 01:28 PM
DatZun280
Jan 22, 2005 07:17 PM
280zinkansas
Apr 17, 2004 03:54 PM
