Fuel tank positioning..
Old Dec 20, 2012 | 08:12 PM
Acasper13's Avatar
Talking Fuel tank positioning..
I have a '77 280z, and i want to move the ugly as gas tank up into the wheel well for exhaust reasons and for the fact that it looks like my cars ***** are hanging out.. i want something like this can anyone point me in the right direction?
1972 Datsun Fairlady Z Roll Cage Photo 7
Old Dec 20, 2012 | 08:52 PM
That's the hatch... not the wheel well.
And I Googled "fuel cell" for you: https://www.google.com/search?q=fuel%20cell
Old Dec 21, 2012 | 07:04 AM
Acasper13's Avatar
Yea but how do imove the tank upwards without unbalancing the weight of the car...
Old Dec 21, 2012 | 08:37 AM
Well... how big of a fuel cell are you going to use? How much fuel will be in it when you are racing? Have you thought about installing the cell where the stock tank is? (most fuel cells are smaller than stock tanks).
Just an FYI, there are tons of "how to balance your car" articles on the intrawebs...
Understanding Corner Weights: Grassroots Motorsports Magazine Articles
Old Dec 23, 2012 | 03:29 PM
69-GnoseZ's Avatar
I wouldn't worry about unbalancing the car. The cell in the pic most likely had a custom holding frame built after the spare wheel well was removed. The holding frame is built inbetween the rear frame rails of the hatch floor. Most common cells used are the 10, 12 & 15 gallon capacity for S30's. The height of the cells are generally between 9.5" & 10.25" If the top of the cell is installed at floor level then the rear lower body panel should completely hide it. Keep in mind that if you are doing any road racing then sanctioned fuel cells must be used. These are generally ATL's & Fuel Safe's. The fuel cell you get from Summitt or JEGS are general purpose made for drag racing cells & won't cut it for road racing.
Old Dec 23, 2012 | 05:01 PM
Acasper13's Avatar
Where should i get a cell for drifting/ drag racing etc..
Old Dec 23, 2012 | 05:25 PM
69-GnoseZ's Avatar
If the event is somewhat professional then see what it or the local track regulations specify. On the whole a drag race (depending on bracket class) will have lower impact standards then drifting or a road race as the possibility of rear impact is lower in drag racing. Go with the higher standard spec that is required. I mentioned 2 companies that make spec fuels cells in my previous post. Then again its your firery death if you choose to cheap out if what you are doing does not have strict safety rules where fueling is concerned.
zpeedracer25
Oct 30, 2016 07:06 PM
FlytMedic
Jan 5, 2013 09:48 AM
kevstr2
Mar 17, 2011 11:18 AM
dapper189
Nov 17, 2008 12:51 PM
280zinkansas
Apr 27, 2004 10:26 AM
