clutch problem
clutch problem
hey everyone, im having trouble with my 71 :/
i have a brand new clutch master cylinder and slave cylinder on the car, but cant seem to get any pressure outve the system.
i bled new fluid through it and pumped it alot, and im pretty sure ive gotten all the air outve it.. i just cant get the slave to actuate the pushplate whatsoever.
the previous owner put the new master on about 23 years ago and put fluid into it. but like i said, since then, ive put new fluid and bled it, plus new slave..
im thinking maybe the master went bad?
anyway it dont seem to work.. this is the only thing holding me back for first test drive.
Did you bleed the master?
It's a really simple system, so when the slave won't move, you know you still need to bleed / re-bleed the system. Bleed the master, then open the slave and pump until a clear stream, then close, pump, hold, open, close. Much easier with two people.
I'd have to say that 23 years ago doesn't sound "New" to me. The master could need to be replaced.
still have no clutch pressure, i dont think i did the 2person bleed part correctly yet however. wasnt patient enough with it and we worked on the engine more instead today..runs good.
another thing im having trouble figuring out is this clutch pushplate where the slave cylinder rod bumps up and pushes the plate.. my plate has a hole in it , the rod just passes through and just floats there.. without pushing the plate.. is the hole in the plate factory, or am i missing parts or?
anyways, i put a bolt through with a flat head on it where it makes the entire pushplate flat and the slave cylinder rod just bumps it.
new master comes in tommorrow.. i tried the pump n hold, open/ shut bleeder, repeat process.. still nothing.. how long does that process take on average? i only did it about 8 times
another thing is if that plate in the picture is what the slave cylinder is suppose to push, im officially scared cuz mine is very different and i cant push it by hand.
i hope i dont have to take all of it apart, but i will if i have to.
thankyou.. i have the old type clutch fork, that makes much more sence to me now with those pictures.. i have the newer type slave on there and it doesnt make sence/ or work, so im going to remove it and put the correct one on, and replace the master aswell because i still got no pressure.
hope to take a test ride soon.
thanks again fellas.
still having a little trouble..
i finnnnallly got the parts i need, and now they are installed..
finally got both the correct master cylinder and slave cylinder with the tapered/adjustable threaded end. new dot3 fluid in the system
dont know the bleed process, and cant get pressure..
snwbrderphat540
28
Apr 29, 2008 11:43 AM
