Toyota brake upgrade + rims
Old 10-23-2005, 12:25 AM
Fast240Z's Avatar
I am seriously considering the toyota 4 piston caliper upgrade for the front brakes on my Z, but I have read that when used with 14" rims, the brakes have issues with size and clearance. What's the smallest rim I can use with the brake upgrade? I have 14" rims on the Z right now, and I like them, so I don't want to have to buy a new set of rims and tires just for a brake upgrade.
Fast240Z is offline
Old 10-23-2005, 07:21 PM
on the S30... there shouldn't be any clearance probs... it's on the 280zx's that the spindle is shorter & spacers must be used.
to make sure, measure the distance from the rotor face, to the end of caliper (out towards the rim) of your Z, and of a toyota 4piston setup... and wa-la... your answer!
NismoPick is offline
Old 10-23-2005, 11:31 PM
redneckz's Avatar
Cool Toyota brake upgrade
Depending on which setup you are using. If you are using the S-12 calibers with the solid rotors, you can use the 14" rims with very little if any problems. I have used this setup with Westerm minilight 14"X7" wheels running Solo II and didn't have any problems. If you are using the S-12W or S-13W calibers with the 300ZX vented rotors w/spacer plate. You will have to upgrade to 15" rims at the least. I am now running a 16" by 7" rim with a 1" spacer with the 300ZX conversion. Good Luck, Rich.
redneckz is offline
Old 10-28-2005, 07:03 AM
You got any pics of that? I'd love to see that setup!!!
Old 10-30-2005, 01:32 PM
redneckz's Avatar
Will be taking the Z car outside tomorrow. I will take some pictures and post them for you.
redneckz is offline
HexaggramJDM
03-31-2011 07:02 PM
apollo
03-19-2007 11:49 PM
toytinker
04-15-2004 09:57 AM
zboy280
05-08-2003 01:05 PM
rusty
05-31-2002 07:07 PM
Quick Reply: Toyota brake upgrade + rims
