Paper or Plastic (air dam )
Hey All,
I need to replace the broken ( shattered ) front air dam
on the Z , and I am wondering what style and material you prefer .
The choices seem to be urethane or fiberglass. I also see MSA has some
bling bling carbon fiber ones for sale now. What are the pros and cons
of each style ?
Thanks,
Mike
of each style ?
Thanks,
Mike
I think the difference is mostly weight and cost. Fiberglass is probably the cheapest and the easist to break. Then you'd go to urethane and then carbon. I use the cheap fiberglass bits myself but have thought about making a airdam/splitter out of sheet aluminum. I seem to damage my airdam about every other race so I kinda consider them expendable.
A neat trick a friend told me about that works great is to reinforce the back with some tubing. In my off this weekend it cracked the airdam and bent the tubing quite a bit. If I hadn't had the tubing the airdam would have been in pieces. I have pins on the car that this fits into and then the top is held with Dzus fasteners.
For at the track repairs I have some thin aluminum, a drill, and a rivet gun. Not pretty but it works. Some colored duct tape wouldn't hurt too.
Cary
Cary
Thanks Cary !!
My Freind built an aluminum dam for his roadster . It is attached using Dzus fasteners , so it could be hammered out when bent . He also take is it off to
load it. I do like the backing tubing idea. It doesn't weigh much and would
give some reinforcement to the dam.
John coffey tried to make a splitter/ dam for his ROD , but I think it was to high
off the ground and the car didn't handle all that well when they tried it out the first time.
Mike
Mike
snwbrderphat540
Oct 26, 2005 05:53 PM
