Paper or Plastic (air dam )
Hey All,
I need to replace the broken ( shattered ) front air dam on the Z , and I am wondering what style and material you prefer . The choices seem to be urethane or fiberglass. I also see MSA has some bling bling carbon fiber ones for sale now. What are the pros and cons of each style ? Thanks, Mike |
I think the difference is mostly weight and cost. Fiberglass is probably the cheapest and the easist to break. Then you'd go to urethane and then carbon. I use the cheap fiberglass bits myself but have thought about making a airdam/splitter out of sheet aluminum. I seem to damage my airdam about every other race so I kinda consider them expendable.
A neat trick a friend told me about that works great is to reinforce the back with some tubing. In my off this weekend it cracked the airdam and bent the tubing quite a bit. If I hadn't had the tubing the airdam would have been in pieces. I have pins on the car that this fits into and then the top is held with Dzus fasteners. For at the track repairs I have some thin aluminum, a drill, and a rivet gun. Not pretty but it works. Some colored duct tape wouldn't hurt too. Cary |
Thanks Cary !!
My Freind built an aluminum dam for his roadster . It is attached using Dzus fasteners , so it could be hammered out when bent . He also take is it off to load it. I do like the backing tubing idea. It doesn't weigh much and would give some reinforcement to the dam. John coffey tried to make a splitter/ dam for his ROD , but I think it was to high off the ground and the car didn't handle all that well when they tried it out the first time. Mike |
