I made a injector thingy today
Old Jun 3, 2009 | 10:21 PM
thetremendousti's Avatar
w0rld's l0ngest m0t0rswap
So I was going to go once again and pay my $20 some bucks to have a couple injectors tested again, and then I had a better idea. I remember reading something about a guy who made his own injector flow testing setup and so I decided to make a crack at it. I went to "U-pick U-save" in gardena and got some injector harness, a FPR, and much needed injector screws but boy did it suck paying for. I dont even think I needed the FPR now that I mention it...dammit...oh well so I made this thing.
I set up a fuel rail, and a fuel pump from a '74 about 4PSI X( but hopefully it'll work...
I'm going to clamp the + end of a jumpstarter from our truck to this metal thing which will automatically start pumping fuel. The white switch will allow current to go to the injectors at 100% duty cycle but only for about 10 seconds
this is the ghettotacular harness all rigged up and the fuel rail
these are shelves that can be set at two different heights
And this is my dog
And that's what the final product looks like
So i'll take a crack at it tomorrow, hopefully I won't blow up too much stuff, tell me what you think. Its so nice to be home...
Old Jun 4, 2009 | 02:07 AM
Sweets's Avatar
Usedta be Justin260z
DUDE THAT'S A GREAT IDEA!!!!!!!!!!!
You could probably run some kind of cleaner through them too.
Your doggie wants inside.
Old Jun 4, 2009 | 08:16 AM
Don't you want stock fuel pressure?
If the fuel pump is from a carbed engine it wont' be the correct flow. 30psi is about right.
Old Jun 4, 2009 | 07:43 PM
Whats wrong with this picture?
I need help, I tested all my connections with a 9v battery and everything holds out fine, the injectors are hot to the clamp point, and the fuel pump is hot to the clamp point as well. The sparks fly on my jumper cables but when I hooked the + to the jump point and the negative to the wood nothing happened.
What am i missing here? I dont want to short circuit anything so i'm taking the precaution of asking you guys.
Old Jun 4, 2009 | 08:48 PM
That darn wood just doesn't like to conduct electricity. You should try something more effective like METAL.
Old Jun 4, 2009 | 09:02 PM
hahahahah I GOT IT WORKING!! I didn't want to wait anymore and I talked with my brother and realized that DC connections are different than AC X( Oh well you learn something new everyday!! The machine is working swimmingly I'll see if i can put up a picture, tomorrow I want to get legitimate cylinders instead of water bottles but everything works awesomely! Anybody need their injectors tested?
Old Jun 5, 2009 | 09:17 AM
Red face
Old Jun 18, 2009 | 10:45 PM
Niku-Sama's Avatar
eff good grammar
dang i was gonna suggest using an old computer power supply, AT style with the clicky button bulit into the wiring of the power supply. ATX you need to jump 2 standoffs on the main connector to get it to turn on, not pretty some times....with gas.
but yea AT power supply look up a pin out and you can get a broad spectrum of voltages to 12 volts.
GTR
Aug 22, 2007 04:03 PM
SHADY280
May 5, 2007 08:30 AM
TBK1
Apr 18, 2007 11:08 AM
nis88300zx
15
Sep 28, 2005 05:14 AM
perfectindustry
Nov 5, 2002 02:16 PM
