High HP L28s
Old Jul 17, 2010 | 02:47 PM
  #76
Originally Posted by skib
89mm is common, thats the bore for a 3.1
theres a few ppl that go to 90mm but that's really pushing it
You can also have it resleeved, but then you would have to start looking at external coolant/oil passages.
Old Jul 17, 2010 | 09:36 PM
  #77
BlueKitsune's Avatar
Intrawebz Wizard
I dont want to go about resleeving the block needlessly. but I'm still blown away but people running such a thin sleeve. I think theres something missing here.
Old Jul 17, 2010 | 10:24 PM
  #78
skib's Avatar
This facepalm's for you!
the higher you go in power/performance the lower down your reliability\longevity goes
Old Jul 17, 2010 | 11:49 PM
  #79
That depends on how well you build it, I used to have a sbc that would regularly see 8400RPM and the temp would be anywhere from 200-270 and it lasted 8 years before a screw came out of the carb butterflies and ended up being punched through the deck of the cylinder head. When we pulled it apart, everything looked beautiful like the day it was put together. (minus the fact that everything was covered in water/oil milkshake. Everything about an engine build depends on the person who builds it.
I have seen some WILD sbc setups that are going on the 10+ year mark without ever being cracked open except for something like a timing set needing replaced and they are all pushing withing 3psi of what they originally pushed when they where first built!
Old Jul 18, 2010 | 01:41 AM
  #80
Intrawebz Wizard
I just need to wait for the books i ordered to get here already so I can get some more information. I'm not going to resleeve the block unless it actually NEEDS it.
Old Jul 18, 2010 | 01:46 AM
  #81
Intrawebz Wizard
There is a compromise between the two tho. But so long as your not extremely pushing the limits of the parts your using it will last a very long time, if taken care of of course. Build it right with tight tolerances, and a very good balanced job, with the right hardware and it will last a long time.
Part of the reason I dont want to resleeve my block. it will make it a little bit weaker.
Old Jul 23, 2010 | 01:48 AM
  #82
WanganDevilZ's Avatar
The Emblem Thief y0!
Hey Blue, I have a better idea, howsabout building reliable midpower L28s, instead of insane HP L28s. Like 220-260hp N/As, and like 300-350 Turbos.
And then build only one Devil Z and sell it for someones soul.
Old Jul 24, 2010 | 10:13 PM
  #83
eh? Sleeving makes the cylinder walls stronger.
Old Jul 25, 2010 | 01:00 AM
  #84
Intrawebz Wizard
lol I might think about it if this becomes to hard to get into the 300s on an N/A
Old Aug 18, 2010 | 04:56 AM
  #85
DatsunKid's Avatar
Get outta my way.
So... where the fudges are all the l28's making 400hp for the cost of 3grand at?
Old Aug 18, 2010 | 09:51 AM
  #86
Intrawebz Wizard
Still blueprinting and testing.
Old Aug 18, 2010 | 02:47 PM
  #87
thxone's Avatar
All my Bone stock 280zx's made 300+ wheel hp... stock.
Old Aug 18, 2010 | 05:50 PM
  #88
Intrawebz Wizard
proof or it didn't happen lol
Old Aug 19, 2010 | 07:10 PM
  #89
DatsunKid's Avatar
Get outta my way.
Well what exactly have you tested so far?
Old Aug 19, 2010 | 07:59 PM
  #90
Intrawebz Wizard
Blocks, cranks, and rods. looking for the right pistons or piston design right now. Were starting from the bottom up. And then we're starting into the head work.
Old Aug 19, 2010 | 11:48 PM
  #91
skib's Avatar
if this is a serious statement...
your a ****ing idiot
Old Aug 20, 2010 | 01:32 AM
  #92
Strong wrist pins, thick dome and lighter then hell. Those are the three things you need to pay attention to when spec'ing pistons for an N/A build.
I can run at 15k RPM all day long on my R1 on cali pump gas without an issue at a weak *** 12.6:1 C/R. This is the type of piston you should be looking for..
http://www.starracing.com/Star/JustR...izePistons.htm
Old Aug 20, 2010 | 09:42 AM
  #93
aren't R1's limited at 14k.... lol
Old Aug 20, 2010 | 01:03 PM
  #94
At the factory rev limiter.
82zxturbo
Nov 1, 2007 06:32 PM
hoov100
Feb 7, 2007 09:10 PM
beez
Jul 9, 2005 02:00 PM
reyazul
Sep 8, 2002 03:06 PM
nissan1990
May 7, 2002 09:33 AM
