bored? check out my progress!!
Old 08-05-2008, 11:16 PM
w0rld's l0ngest m0t0rswap
thetremendousti's Avatar
http://www.facebook.com/album.php?ai...&id=1034520060
Enjoy my other albums!!
thetremendousti is offline
Old 08-05-2008, 11:23 PM
cools i dint se a tranny though? also shoulda tooken the opportunity to paint the block and clean the bay. oh well
snwbrderphat540 is offline
Old 08-06-2008, 06:19 AM
Not bad not bad... I added ya on mai faceboox.
NismoPick is offline
Old 08-06-2008, 09:25 AM
Thats the transmission, I put it in first. Hence the caption...
Mating it was suuuper easy, and I"m sooo glad i went tranny first!
Just a quick question.
what is this hose supposed to be attached to? Hahaha
Old 08-06-2008, 09:27 AM
looks possibly like PCV but cant tell for sure got a better pic?
Old 08-06-2008, 09:29 AM
Indeed.... PCV valve. It's almost touching it!
Old 08-06-2008, 10:32 AM
damn n00bs i dont even own a Z and i knew that ROFL
Old 08-06-2008, 12:31 PM
zstreet86's Avatar
i added you to my facebook too, hey nismopick, whats yours?
zstreet86 is offline
Old 08-06-2008, 01:02 PM
well @(*#(@ now i have a ton of time. I jsut got a call and I can't afford to go to college in Illinois now...IT's a real big bummer but that means I have more time to work on it, but now i'm on a roll. Yeah I just read all about the Positive Crankcase Ventilation system but on the N42 I don't believe there is a PCV valve on the manifold, so can I just cap off the vaccum?
Old 08-06-2008, 01:06 PM
The open end of the hose you were asking about should almost be touching the PCV. I'm pretty sure the N42 has one... this one does:
Old 08-06-2008, 01:09 PM
I've pointed it out for you in the attached pic.
ZStreet, here's my facemagazine: http://www.facebook.com/people/Marc_...ing/1282269282
Old 08-06-2008, 04:24 PM
N42 has one but since it was for an NA motor its RIGHT over the turbo you will have to relocate it or plug it in the manifold and just run a filter off the block. also cant afford college in IL? come on.... loans beotch loans! or beg the p-units haha.
Old 08-06-2008, 07:11 PM
Turbo!
Bleach is offline
Old 08-06-2008, 09:02 PM
Pr0n Addict
KasbeKZ's Avatar
i'm mr. facebook noob. i added you too nismo.
this project looks fun. i wish i was doing it! try to get a video after it's done. i want to see how fast it is!
KasbeKZ is offline
Old 08-06-2008, 11:14 PM
I know i'm realy excited i've been reading my haynes on what i need emissions wise and It looks like I need the PCV system...I am running into this problem of where to plug the crankcase tubing into because the PCV valve on the manifold is a plugged by my turbo
Would it be catastrophic if i just plugged off the crankcase ventilation and just had it recirculate through the rocker cover? This emissions is so confusing i don't know what i need for the turbo system but I'm still reading so..
Old 08-06-2008, 11:55 PM
NisTuner
duowing's Avatar
I believe that someone on hybridz mentioned going to home depot and getting like a bent fitting so you could keep the PCV. Otherwise you'd just plug off where it's at and drill and tap a new hole over a bit.
duowing is offline
Old 08-06-2008, 11:59 PM
eff good grammar
Niku-Sama's Avatar
will it run with out it?
Niku-Sama is offline
Old 08-07-2008, 12:51 AM
Found it
http://forums.hybridz.org/showthread...hlight=N42+PCV
Old 08-07-2008, 09:44 AM
Queen of Yachts
z-hag's Avatar
Location: warmspott, trollville.......somewhere sailing the seas--fla, virgin islands...wherever....warm water....LOL
sammich was reallly reallly gooood.........miaourw
z-hag is offline
Old 08-07-2008, 10:22 AM
i already said what you had to do! plug it and re-tap so it reaches or just plug it and then just vent the PCV hole in the block to the atmosphere. idk how i keep getting ignored when im right....
Old 08-07-2008, 10:31 AM
huh? whad you say? I wasn't paying attention.
Old 08-07-2008, 10:34 AM
i think its cause i have a kawi instead of a datsun/nissan. lol. well at least i got you pick and thxone for kawi bros.... though mine is way more BA lol
Old 08-07-2008, 12:16 PM
http://forums.hybridz.org/showthread...=n42+turbo+pcv
"Notice the tube from under the intake manifold to the crankcase hole, and the shiney silver filter?? well that didnt work"
Old 08-07-2008, 02:20 PM
how about running both the block and valve cover vents into one oil catch can. Then output from that can to the intake in front of the AFM. It will always have slight vacuum there.
Bleach is offline
Old 08-07-2008, 04:05 PM
NisTuner
duowing's Avatar
that's not too bad an idea bleach
I've also read someone saying their idea for removing the carbon canister, was just running the vent line right to the intake manifold. Person said they had been running it for a while like that with no problems.
duowing is offline
Quick Reply: bored? check out my progress!!
