Won't Start?
Won't Start?
I drove my Z32 '90 2+2 the other day, and it was fine. Now it won't start. The battery is new, cranks great. Just won't 'catch'. I did remove all of the rear hatch interior and install a rear strut bar today, though I wouldn't think that has anything to do with it. Rear hatch and doors were open most of the day, so I went to start to ensure that I didn't drain the battery, and it won't start. I'm I suppose to hear a hum from the fuel pump when I initally turn the key? If so - there is none. I did replace the fuel lines and fuel filter last weekend when I installed the front strut bar, though I have driven it since then without any problem. Could there be a breaker or something like that for the fuel pump? I am confused!
Any suggestions would be appreciated.
Thanks!
Any suggestions would be appreciated.Thanks!
OK - I feel Like a Fool!
As you will see, I don't have a problem admitting when I am wrong.
When I had the rear seat out of my 2+2 and the rear driverside - side panel, I went ahead and disconnected the plugs to the old Bose amp system. Ovbiously, I got to over zellas and unplugged the wiring harness to the fuel pump. After I checked the fuses, I remember about unplugging those plugs. Since the car was fine before the installation of the rear strut bar, I figured that it had to do something with what I did today. I removed the rear seat and side panel, re-connected the plugs I undid earlier today, and it started right up. Obviously - operator error!
I can't believe that I did that!
Oh - well - everything good now!
Thanks!
Oh - well - everything good now!Thanks!
Originally Posted by KevinH
....... I got to over zellas and unplugged the wiring harness to the fuel pump........
bongpogi
Aug 19, 2015 11:15 AM
moorebl
Apr 14, 2011 03:28 PM
