Wont crank but clicks. Fuel Injector?
Old May 13, 2010 | 07:11 AM
domsgarage's Avatar
Tough Guy
Was running great for like a half hour. Theres a miss but it was idling fine and running well.
I pulled the injector thats bad, put a new style one in, not remembering that the fuel rails are different.
I tried to start it, it turned over for a second then died out. Then there was a weird sound, like a buzzing kind of and it wouldnt start. It would just crank for maybe half a second, then the starter would just click.
Put the old, bad injector back in thinking that was the issue.
It did the same thing, made a loud click, like it tried to turn over and then just wouldnt, but the starter still clicks.
Could it be the starter?
Could something have happened when I put the new injector in by mistake?
Its strange because i just reversed the steps and the car was running well before the injector.
Any ideas would be a solid help, im going out there now to look at it some more.
Thanks
Old May 13, 2010 | 08:59 AM
KasbeKZ's Avatar
Pr0n Addict
your battery is dead son. put a charger on it.
Old May 13, 2010 | 09:02 AM
domsgarage's Avatar
Tough Guy
Come on now. Its been charging all night. I might have fried it though. The negative terminal was smoking a little.
Old May 13, 2010 | 09:24 AM
domsgarage's Avatar
Tough Guy
Theres a little grinding sound to it as well. Like itll crank then grind (maybe the starter grinding). I dont think its something as simple as the battery.
Old May 13, 2010 | 10:40 AM
xpwarrior's Avatar
If you put a new style injector in an old style fuel rail wouldn't it have poured gas into the intake? Maybe you have hydrolocked the engine.
Old May 13, 2010 | 11:10 AM
domsgarage's Avatar
Tough Guy
I can manually crank the motor so its not locked up. It manually spins like it would if i normally spun it.
Old May 13, 2010 | 12:04 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
If it's not cranking, it's your battery or your starter. You injector CANNOT prevent the motor from cranking on startup. If your battery was smoking, it's probably fried. (Clicking is normally tell-tale of a weak battery.)
And yeah you cannot just drop a new style injector into the old rails. How did you even connect the new style injector to the wiring? They have different connectors...
Old May 13, 2010 | 12:34 PM
icice9's Avatar
Super Siver & Black Stud
it also sounds like your not getting a good connection on your battery terminal.. you said your negative terminal was smoking a little bit. that might be due to a bad connection.. clean your batter terminal and try cranking it again...
Old May 13, 2010 | 01:45 PM
domsgarage's Avatar
Tough Guy
It was the bad injector, it was leaking into the cylinder.
I suctioned out the fuel and it fired up.
eZdoesit
Aug 12, 2011 07:17 PM
datdude407
Sep 13, 2010 09:44 AM
Wishihadahonda
Oct 14, 2009 12:36 PM
DualZ
Mar 19, 2009 02:25 PM
91black2+2
15
Jan 3, 2007 07:52 AM
