tuning up my z.....???
Old Jun 1, 2003 | 10:52 PM
NISMO LMR's Avatar
what we did was an IATC (intake air timing censor) mod. this is a lot of noticable horse power. they say around 20 at the crank, that is a worst lie than when bill clinton took the stand. it adds maybe 8-9 hp at the crank. but stil, that is VERY noticable. heres a little nifty fact, if you install it backwards, you timing belt breaks!. so make sure you have a mecanic install it. other wise, well, its selfexplainitory. you can find these on Ebay, just type in "300zx intake", and about 200 or so should come up. peace
Old Jun 13, 2003 | 07:30 AM
Riz Z Speed's Avatar
Administrative Brown Guy
I also have an na, so I'm in the same boat. Simple tune-up stuff works best like that which you've already done plus don't forget the fuel filter and the pcv valves! Make sure your belts are in ok condition. Have your alternator checked if its oem, they have a tendency of dying on ya. Also a good idea to have spare fusible links especially that 45amp blue wire one. When that blows nothing in your car responds electrically!! I had fun figureing that one out. Good Luck.
Old Jun 30, 2003 | 06:03 AM
drag_300japan's Avatar
Did somone say FANS? NO the other kind. The electric type will give you a few extra also a lightened crank pullythat will be noticable change! You Can adjust the timing a little, the old school way was to move the timing belt a notch or to but cam gear pullys are a better way to go. Better air intake pipes with ceramic coating to keep the radiant heat from heating up the air before it goes in the motor. You can get a chio for your ecu. The list goes on and on. The problem is, once you get to a certain point the hp get more costly to make. Hope that helps you guys!
chevyss772
Dec 16, 2009 08:59 PM
Superduner
Sep 9, 2006 01:31 PM
kris_1371
Feb 12, 2006 06:05 PM
forcedfedz32
Oct 3, 2005 04:05 PM
yRz
May 17, 2002 06:15 PM
