tuning
Old Dec 16, 2009 | 04:42 PM
chevyss772's Avatar
tuning
is there software you can use on a labtop to tune the s130?
maybe sauter a usb in the ecu ?
Old Dec 16, 2009 | 05:14 PM
reddzx's Avatar
No, that won't work with the stock system. You will need a stand alone engine management system for that. And that's only nessessary if you increase the size of the injectors, turbo it and increase fuel volume.
Old Dec 16, 2009 | 05:59 PM
260zturbo's Avatar
Stupid Hurricanes...
how many crapzilla post you plan to make chev?
Old Dec 16, 2009 | 07:45 PM
+2 ^^^
Old Dec 16, 2009 | 08:59 PM
PurePontiacKid's Avatar
i felld offa mai trike
Of course, since the 280ZX system is so complex, you need to download Asteroids to your laptop. But simply doing that won't do it. You need to beat levels to be able to tune different things on it. like beating first level lets you adjust the ECU within stock levels. Beating second level allows you to slightly alter the fuel tables a little more. But beating Asteroids will allow you to have full control over your tables, full X,Y,Z everything
HOWEVER, if you want to adjust the ignition maps, you have to download Ms. Pac-Man (NOT ORIGINAL PAC-MAN, IT IS NOT COMPATIBLE) and go through the same process.
Superduner
Sep 9, 2006 01:31 PM
kris_1371
Feb 12, 2006 06:05 PM
forcedfedz32
Oct 3, 2005 04:05 PM
allmotor300z
Apr 13, 2005 10:15 PM
yRz
May 17, 2002 06:15 PM
