TT and NA Gearbox Differences?
Old Jan 29, 2006 | 09:00 PM
260DET's Avatar
According to the workshop manual the two manual gearboxes have the same ratios, the only apparent difference is that the TT box holds more oil.
Is this the only difference? How do you tell the difference between the two externally?
Old Jan 29, 2006 | 09:05 PM
bardabe's Avatar
Bad Speller
Bell housing, the BEll housing on N/A is smaller.
-Juanton
Old Jan 30, 2006 | 01:07 AM
260DET's Avatar
Thanks Juanton, anything in particular that can be ID'd without putting two side by side?
Old Jan 30, 2006 | 11:18 AM
Mousier158's Avatar
a trained eye...other than that there isnt anything that i know that sets the two apart. sorry.
Old Jan 30, 2006 | 07:45 PM
260DET's Avatar
OK thanks, thats a help anyway
Old Feb 1, 2006 | 06:16 AM
WhtFairLadyZ's Avatar
The bell housing difference is the only thing different. Both bell housings are the same bolt pattern and will bolt up to either NA or TT motor. But the TT has a larger diameter flywheel than the NA. THus, when bolting a TT tranny to a NA, you will need to grind down some metal unless you also add a TT flywheel. Am i right on that guys? THat is what i have understood, and it seems logical.
Old Feb 1, 2006 | 08:47 AM
Aphrodite's Avatar
yep thats exactly right
check out page 4 of this
Old Feb 1, 2006 | 01:20 PM
for htat being the only difference dont you think nissan wasted alot of design and manufacturing money doing that? i mean im not seeing a great reason for doing that between the 2 am i missing some logical explination?
Old Feb 1, 2006 | 03:38 PM
Supposedly something to the effect that the NA clutch wont handle the power of a TT engine was what I was told. I dont see why they didnt jsut use the same flywheel and just change the clutch material or the clamping force with the springs. I think it is retarded myself.
3riCJbOi
Aug 1, 2008 08:11 PM
BC240Z
May 30, 2007 10:11 AM
ever888
May 16, 2007 12:34 PM
mark6458
Sep 13, 2005 01:15 PM
zxbornNbred
Jun 23, 2002 02:10 PM
