auto gearbox problems in the wet
Old Sep 10, 2005 | 11:08 AM
mark6458's Avatar
hello everyone
just bought 1990 z32 runs lovely until it rains,then it does'nt want to change gear and idles at 2000 rpm's also high beam headlights come on and stay on until everything drys out. once dry everythings back to normal,would be very grateful for any ideas you may have. many thanks Mark
Old Sep 10, 2005 | 11:27 AM
CanyonCarver's Avatar
Jack Of All Trades
I hate electrical problems. Here's some initial areas to look.
1) The problem is somewhere that gets wet. duh, I know. meaning it's prolly in the engine bay and not under the dash.
2) Your highbeam headlight circuit. There's not too many of those wires. They're making contact with another hot wire somewhere.
3) High idle might just be a byproduct of a large current draw somewhere
4) Not changing gears could be the speed sensor circuit Does your speedo work when it's wet? Or the a/t ecu. Again, maybe due to a high current draw elsewhere, or the high beam wire short is in an area of the a/t ecu / speed sensor circuit wiring.
One of the bummers is that it might not act up for a while. One thing to try the next time it acts up, is to pull the headlamp fuses from the fuse box on the fender well and then see if everything else works o.k. If so, then you've narrowed things down to which circuit the short is in.
Good luck
Old Sep 13, 2005 | 01:15 PM
mark6458's Avatar
Many thanks,just got to wait for rain now,and have a look see. Mark
Punchiest
Jun 17, 2013 04:54 PM
wbr15
Mar 5, 2011 02:22 PM
3riCJbOi
Aug 1, 2008 08:11 PM
1stz32
Jun 24, 2006 04:28 PM
zxbornNbred
Jun 23, 2002 02:10 PM
