tt injectors in an na
Old 09-03-2008, 10:48 PM
1slowz32's Avatar
ok so i have one injector that has gone bad, reading 2 ohms which i havent really heard of them reading low ohms. i can get a set of tt injectors from a friend for a little more than what one injector will cost, what i need to know is if the na computer can/will compensate for the bigger injectors and not spray way too much fuel or will they spray entirely too much?
1slowz32 is offline
Old 09-04-2008, 12:30 AM
Pr0n Addict
KasbeKZ's Avatar
it'll spray a little too much. if you keep the same ecu you will be rich. i can't say how much.
KasbeKZ is offline
Old 09-04-2008, 09:50 AM
Encyclopedic Knowledge
ZLover4Life's Avatar
You would need to get an ECU program for 370cc/min injectors. JWT, Ash, or ZTuner could make such a program.
But your ECU absolutely cannot compensate for larger injectors by itself.
ZLover4Life is offline
Old 09-04-2008, 08:55 PM
91zxtt's Avatar
There's a slight understatement. If it'll run, it'll run terrible. Rich doesn't begin to describe it.
91zxtt is offline
Old 09-04-2008, 09:50 PM
Yeah, about an extra 43% fuel flow... that'll run just a tad rich. [/understatement]
Old 09-05-2008, 09:18 AM
Pr0n Addict
KasbeKZ's Avatar
maybe (i'm not too sure), but maybe that's why i said "i can't say how much", because i didn't know for sure how much, but i wanted to answer to the best of my ability.
KasbeKZ is offline
Old 09-05-2008, 01:57 PM
Just add 43% "NOS!"
NismoPick is offline
Old 09-05-2008, 06:58 PM
just add enough compressed air to compensate for the extra fuel and you should be alright, i heard that nissan made a turbo model of the 300zx, but i think its just a rumor. i think the junkyard is in your future for getting a set of injectors and have them cleaned and serviced.
hoov100 is offline
Old 09-05-2008, 07:42 PM
That's an awesome solution! Why didn't I think of that? Put on turbos that introduce just enough extra air to compensate for the extra fuel! Brilliant!
Old 09-05-2008, 09:11 PM
91zxtt's Avatar
Here's a novel thought....why don't you just answer questions when you actually know the answers. Clearly the best of your ability in this case allows you to park in a handicapped space.
91zxtt is offline
Old 09-05-2008, 09:57 PM
caught the z fever
b300z's Avatar
lol that was pretty harsh. even for you
b300z is offline
Old 09-05-2008, 11:18 PM
He was right about the important part (that it'll spray too much) just not the result (that it likely wouldn't run).
Old 09-06-2008, 12:58 PM
nismo619's Avatar
I know when i put 280zxt injectors into my " X GURLS FRIENDS " 280zx n/a/ it build up so much pressure inside the gas tank that when i went to open the gas cap gas shot out at me ! her car ran mean as hell for about 2 days... lol fould out the spark plugs... maybe if she put in a high performece coil high output than maybe... maybe not.. lol ?
nismo619 is offline
Old 09-06-2008, 02:56 PM
no, putting more air into the cylinder will burn the extra fuel.
hoov100 is offline
Old 09-06-2008, 09:06 PM
91zxtt's Avatar
maybe.....maybe not. Need to keep the FNGs in check.
91zxtt is offline
Old 09-09-2008, 05:52 PM
Pr0n Addict
KasbeKZ's Avatar
well, to the OP, i apologize for saying that it will spray a little too much. it looks like the correct answer is..... it will spray too much. hope we are cleared up now
KasbeKZ is offline
Old 09-09-2008, 05:56 PM
Obsessive Craigslist Disorder
rtmorgan's Avatar
kas dont you have homework to do?
i posted on you thread read it
rtmorgan is offline
Sam
06-06-2010 03:24 AM
thetremendousti
08-14-2008 09:42 PM
Comrade_Charlie
05-07-2007 02:13 PM
Mooney
11-03-2005 09:42 PM
notazowner
05-25-2005 02:51 AM
Quick Reply: tt injectors in an na
