trany ?s
Old Apr 18, 2010 | 12:07 AM
Lanoi's Avatar
trany ?s
How good are the trans on z32s? Tonite i parked my car and let it run for a bit. And when i jumped in the car to drive. i put it in reverse and it didnt ingauge. moved my foot off the clutch and didnt move . Or any gear. Then i turned the car off wait like 25 mins started it up and tryed again this time it worked but it felt like i had my foot on the clutch, so it would barly go. i was in 1st gear, gave it gas and rpms went up like i had clutch down but i didnt and car started to pick up in speed but very little. After a while it started to work like normal. anyone have this problem?
Old Apr 18, 2010 | 04:51 PM
Lanoi's Avatar
for anyone reading this i adjusted the clutch pedal i read up and i didnt have enough free play so the back the rod back a bit. Imma drive around and see if the problem comes back wish me lucky
Old Apr 18, 2010 | 05:16 PM
KasbeKZ's Avatar
Pr0n Addict
the trannys are fine. the problem i def your clutch. transmissions don't slip. it's either in gear or it's not.
Old Apr 18, 2010 | 06:13 PM
Lanoi's Avatar
clutch . pressure plate, throw bearing, new installed friday 2 days old lol
Old Apr 18, 2010 | 07:11 PM
KasbeKZ's Avatar
Pr0n Addict
either, you got grease on it when you installed the clutch (or any other contaminant), or more likely, it's a hydraulic clutch problem, which is the "clutch " issue that i was referring to in my original post.
Old Apr 18, 2010 | 07:23 PM
Lanoi's Avatar
i think when i installed the clutch master cyclinder i had the rod almost as far out as it could go. And even with my foot off clutch it still had some pressure so the clutch wasnt grabing all the way like it should. I just got back from driving around for a while and the problem didnt happen again. So the adjustment did help so far. More driving will be need.
FubarI33t
Dec 10, 2006 11:03 AM
dr. buddha
Jan 19, 2005 07:36 AM
dr. buddha
Jan 12, 2004 10:29 PM
sean6tt
Oct 31, 2002 02:46 PM
Z_addict
Jul 19, 2001 05:36 PM
