sounds like ...
Old Dec 8, 2003 | 12:49 AM
pearly whites's Avatar
turboZdriver
sounds like ...
sounds like a scratchy rubbing noise. it seems to com from the lower corner of the windshield on the passengers side from under the hood somewhere. what could this be. its a kinda slow rub too. like a half note or something.
Old Dec 8, 2003 | 04:36 PM
Riz Z Speed's Avatar
Administrative Brown Guy
Check your tire. Make sure the upper a-arm isn't rubbing against it. If it is you either have an under inflated tire or your alignment is way off.
Also check, while you're there, that the inner fender lining isn't rubbing against your tire.
Is the hood loose? Check the bolts that hold the hood to the hinges. Try raising the hood stops that are at the front corners of the engine compartment. Is the battery tight? If not that could be sliding around causing your noise.
Old Dec 8, 2003 | 11:03 PM
turboZdriver
it does it while idle just sitting in the driveway.
jrealmuto1
Jul 29, 2009 07:48 AM
Niku-Sama
Sep 5, 2008 04:29 PM
chinesekid
Jan 22, 2008 08:32 PM
swank350z
350Z Performance / Technical
Oct 8, 2004 04:58 PM
Tuuurbo
Oct 16, 2003 06:26 PM
