sounds like i have a major problem again
so yesterday i went took my Z to woodlen hills, about 50 miles from where i live, so we'll say about 100 miles there and back... start up my car today and when i let go of the cluch it makes a loud grinding noise.. it makes it when im in first, revise, any gear when i let go of the cluch... so? any advice?
Originally Posted by chinesekid
yea, imma just get a new cluch kit while im at it.. and all that..
But all in all, a good learning experience.
ahh trannys. you got to love em.
I got lucky. I put a old clutch in when I did my tranny swap, 30K miles down the road and still pullin hard. Removin the tranny is easy. It's those top two bolts I hate. I'd replace the slave while your there. Maby even the line if it looks rough. Like hoov said. "It's the crap you do while your at it"
Throw out bearing.. but i got a question for every one else about clutch slipedge ? when im driving my 82 280zxt in 1st to second to third gear the rpm meter peaks with just a touch of gas.. meens my clutch is sliping right ? in time for a new clutch.. its a stock clutch from nissan its been on my car for 9 years and only put about 30,000 miles on it.. should i get another stock clutch ? or get a stage 1 or stage 2 clutch kit ?
Seems to me most high performance aftermarket clutches don't last nearly as long as factory clutches, at least with a stock engine. I wouldn't go more than a stage 1 on a daily driver, maybe even just use a stock disk, with a stage 1 pressure plate.
or a ratcheting wrench. dot put a aftermarket throw out in it thu. they dont last as long as the clutch. nissan only for those things. trust me and while your at it, replace the guide bushing in the end of the crank with the needle bearing unit.
just use a normal wrench, those top 2 bolts are easy as well. and whats with "stage" crap. that means nothing to me. use real car terms such as how many pounds the pressure plate is, the disc make up, disc or puck.... etc.
i hate stage's.
i hate stage's.
Stock clutches don't like tons of hard abuse.
first of all, isn't it that the throwout bearing pushes on the clutch pressure plate only when you push the pedal down.
I thought Kid was saying the grinding was when the pedal was up (when all the gears inside the tranny are spinning)
Seems like the gears in the front half of the transmission are bad, or the main input shaft is going out.
But, since the grinding is gone its all good
thats what i wanted to hear!! hahah but i dont wanna drive it then 1/2 way into where im going it breaks on me... lol
but yea.. when i push in the clutch to start the car its okay... then when i let go of the clutch (even in N) to let it worm up... it grinds.. well before it did
Hum... big mechanical problems don't just come and go by themselves. Not much you can do. Either rip into it, or wait till it starts making the noise again. Make a vid if it does come back.
so, i took my car to work today thinking i was gonna change my clutch and pilot bearing and throw out bearing.. i went to drain the tranny and no fluid came out at all!! like 5 drops... so i put gear oil in it and then everyhitng works but it makes a wineing sound on 1st 2nd and 3rd... other then that, everything seem okay... and when i was driving my "door light" came on.. and it doesnt wanna go off so my floor pannle light keep staying on
