somthings up with my motor:(
Old Nov 22, 2003 | 12:52 AM
Riz Z Speed's Avatar
Administrative Brown Guy
ok, you're probably describing the Cam Angle Sensor (CAS) but you didn't mention if your car is running badly because of it. That'll just advance or retard the timing. A little advancement is ok. It won't hurt the car, might actually help depending on how far advanced. If it's only a few degrees off, you're fine.
Old Nov 25, 2003 | 07:33 PM
All the way to the right is fully advanced. You'll need a timing light to correct the timing. If you don't have one try a trusted mechanic or shop. 15degrees is the correct reading. Is your car a California emissions car? If it isn't that could also be a problem. To check, look under the hood. There should be an emissions sticker giving all of the information stuck on the underside.
The hiccup you mentioned could be that or some other things. Check your hoses for a vacuum leak. You might want to have the throttle position sensors checked as well.
And yes, California emissions and gas does suck! LOL
davidjoe007
Jun 29, 2021 04:45 PM
19-300zx-90
Sep 17, 2012 05:54 AM
Zphillips
Jul 7, 2009 08:37 PM
86300zx
Aug 15, 2006 08:47 PM
81s280zx
14
Oct 7, 2005 10:48 AM
