Pop Charger
Old May 16, 2005 | 04:52 PM
nismo613's Avatar
Pop Charger
With the JWT pop charger, is that just the filter, or does it come with piping as well? If i do a pop charger, how much hp can i expect to gain? What about going with an injen intake?
Old May 16, 2005 | 04:56 PM
b300z's Avatar
caught the z fever
JWT is just the filter and venturi ring...no pipes
you will see somewhere around 5hp from any intake
Injen will be the same, except you can get it with the pipes...theyre expensive tho
you could save some money by buying the JWT pop charger and using the pipes from an ebay intake kit.
Old May 16, 2005 | 05:30 PM
nismo613's Avatar
In regards to those ebay kits, even though they say they are for a Z32, do you think i will have to do some sort of modifing to the pipes to get them to fit because they are generic? How does the pop charger sound?
Old May 16, 2005 | 07:18 PM
WhtFairLadyZ's Avatar
I have the JWT pop charger..it does not come with the piping. Just what b300z said comes with it. I do however have the hard intake pipe kits for my NA from a company called RVM. Z1 sells the kit that comes with everything u need. Nothing really had to be modified,except for the fact taking them on and off are a bit tricky since they do not flex.
Old May 16, 2005 | 08:28 PM
KENZ's Avatar
Silvered Hawaiian
i got the ones from injen, and im happy with it. to me what ever is the cheapest
Old May 16, 2005 | 08:32 PM
Seraphic's Avatar
Loves The Asian Chicks
lol get DOOLZ from AshSpec. those look sweet
Old May 16, 2005 | 09:18 PM
CanyonCarver's Avatar
Jack Of All Trades
K&N all the way with ngk....
Old May 16, 2005 | 09:42 PM
nismo613's Avatar
Does the doolz come with two intake filters?
Old May 16, 2005 | 10:12 PM
Seraphic's Avatar
its for 2 but im not sure if you get filters with it, check it out here. ^.^ its what im getting for my Z
http://ashspecz.com/ashspec/doolz/doolz.htm
Old May 17, 2005 | 06:45 AM
ZXDude90's Avatar
Aqua Teen Hunger Force Fan
The dual intakes are really designed for TTs. I'm afraid the N/A won't see much benefit unless you are doing a swap of course.
Old May 17, 2005 | 10:49 PM
91zxtt's Avatar
DOOLZ on an N/A is a total waste of money. The DOOLZ requires an EPROM upgrade. I don't believe it's available for the N/A. Just go with Injen.
Old May 18, 2005 | 07:50 PM
TT only go tot he DOOLZ version when power levels reach above 450 or 500 rwhp..other than that it isnt needed.
Darkmann
22
Feb 12, 2008 11:25 AM
ludameister45
Jan 20, 2007 09:31 PM
Logan8er
22
Jul 12, 2006 11:13 AM
NISMO92300ZX
Oct 27, 2002 09:47 PM
