Pop Charger
Pop Charger
With the JWT pop charger, is that just the filter, or does it come with piping as well? If i do a pop charger, how much hp can i expect to gain? What about going with an injen intake?
JWT is just the filter and venturi ring...no pipes
you will see somewhere around 5hp from any intake
Injen will be the same, except you can get it with the pipes...theyre expensive tho
you could save some money by buying the JWT pop charger and using the pipes from an ebay intake kit.
In regards to those ebay kits, even though they say they are for a Z32, do you think i will have to do some sort of modifing to the pipes to get them to fit because they are generic? How does the pop charger sound?
I have the JWT pop charger..it does not come with the piping. Just what b300z said comes with it. I do however have the hard intake pipe kits for my NA from a company called RVM. Z1 sells the kit that comes with everything u need. Nothing really had to be modified,except for the fact taking them on and off are a bit tricky since they do not flex.
its for 2 but im not sure if you get filters with it, check it out here. ^.^ its what im getting for my Z
http://ashspecz.com/ashspec/doolz/doolz.htm
Logan8er
22
Jul 12, 2006 11:13 AM
