Please help! No start!
Old Jul 8, 2010 | 08:45 PM
ChicoB's Avatar
Hey guys I need urgent help.
I have a 93 NA Z32 and it will not start....no clicking, no cranking, starter doesn't turn at all. I have replaced the starter relay and the starter itself. I have checked every fuse I can find and I cant find a blown one. Does anyone have any idea what the cause could be?
It was starting and running perfectly, then a quick trip to the store and nothing.... :wtf2:
Old Jul 8, 2010 | 09:58 PM
ChicoB's Avatar
Also.....There is strong 12v to the starter, contacts cleaned, battery charged-clean contacts, good power to the relay, all accesories work, fuel pump builds pressure, etc....
Old Jul 8, 2010 | 11:03 PM
evandubya's Avatar
Primer Grey FTW!
check your grounds, I just had the same problem found a loose ground connection then I had power
Old Jul 9, 2010 | 04:06 AM
KasbeKZ's Avatar
Pr0n Addict
2nd that. the starter has a hot, it must not have a ground. use a multimeter just to test for continuity between the negative post on the starter (it does have one right? haven't seen it in a while), and just about anything else. you should know what on the engine is grounded.
zcooks
Apr 11, 2016 06:36 AM
bongpogi
Aug 19, 2015 11:15 AM
moorebl
Apr 14, 2011 03:28 PM
bardabe
Sep 21, 2004 03:12 PM
