Oil pressure sending unit, temperature sending unit
Old Aug 15, 2005 | 04:11 PM
nismo613's Avatar
Where exactly is the oil pressure sending unit, and how hard is it to change out?
I have the same question for my outside temp sending unit. B\Both of them need to be replaced. Thanks
Old Aug 15, 2005 | 07:11 PM
DanZ32's Avatar
Dan's the Man
Oil Pressure sending unit is right by your oil filter. Easy change. Screw off old, screw in new.
By temp sending units, I'm assuming you mean coolant sending sensors. They are located in front of your timing covers. There are two. One reads to the ECU and the other to your temp gauge. Facing the car, the ECU sensor is on the left.
Check the wiring for the ECU unit. With time and heat it can get brittle. A relacement harrness for this snsor is only $15. Might consider changing that out as well.
Old Aug 16, 2005 | 02:53 PM
nismo613's Avatar
Thanks for the info! I didnt describe the temp sensor very well that i was talking about though. I meant the ambient temperature sensor that reads out on the climate control. Know where that is?
Old Aug 17, 2005 | 12:25 PM
DanZ32's Avatar
Dan's the Man
Not sure I have a complete answer for you or not.
On the dash, passenger side. There is a little flat sensor that plugs right into the right side of the defrost vent. That is a sun-sensor. I know it is used for defrost but not sure if that is used to measure ambient temp as well. It may very well be.
The FSM would probably confirm or deny that.
Old Aug 17, 2005 | 01:19 PM
Riz Z Speed's Avatar
Administrative Brown Guy
climate control temp sensor is located over head in the t-bar.
part of the fan and reading lights.
Old Aug 17, 2005 | 04:18 PM
DanZ32's Avatar
Dan's the Man
There you go!
I knew the fan was in there, didn't know the sensor was there as well.
I'm all smarter today now.
Old Aug 18, 2005 | 12:43 PM
nismo613's Avatar
Whats that little fan for?
Old Aug 18, 2005 | 02:10 PM
fan keeps constant airflow over temp sensor so it can measure cabin temp.
Old Aug 19, 2005 | 08:25 AM
nismo613's Avatar
So where would the ambient sensor be that reads the outside temp?
Old Aug 19, 2005 | 08:57 PM
91zxtt's Avatar
There isn't one.
Old Aug 20, 2005 | 07:44 AM
nismo613's Avatar
There has to be one, how would it read ambient temperature if there wasnt a sensor
Old Aug 20, 2005 | 11:31 AM
What does the temperature outside of the car have to do with the temperature inside the car?
The only reason i would see for having a temp sensor outside the car would be to tell you what the temp outside is, and our cars don't do that.
Old Aug 20, 2005 | 11:38 AM
nismo613's Avatar
I didnt say it had anything to do with the inside temp. And yes our cars do tell you the outside air temperature. It's displayed as the ambient read out on the climate control. The thing that says "AMB." Ambient is for outside temp. I know it has nothing to do with the temp inside. Unless you can tell me what the ambient read out is.
Old Aug 20, 2005 | 02:28 PM
what thing says "AMB?"
Where can i access the ambient temperature from my climate controls?
Old Aug 20, 2005 | 03:09 PM
nismo613's Avatar
You know how your climate control has the digital read out? Like, you have your set temp, and it will digitally read out what temp you set it at? Well its the number right under your set temp. That is your ambient display. Maybe you dont have the digital climate control? How do I insert a picture so I can show you what i'm talking about?
Old Aug 20, 2005 | 06:59 PM
go to Go Advanced in the quick reply section, there you can upload your pics via the Manage attachments function.
And i have a '93, i have the digital climate controls. Only some early 90's models had the manual controls.
Old Aug 21, 2005 | 09:27 AM
nismo613's Avatar
The ambient read-out is the number that im pointing to in the picture. That is the outside air temperature.
Attached Thumbnails Oil pressure sending unit, temperature sending unit-100_1285-1.jpg
Old Aug 21, 2005 | 01:42 PM
Jeff TT's Avatar
The ambient temp sensor is fitted behind the front bumper or clip as you guys call them, it is a small black unit with a short section of cable on that is clipped to the air con dryer which looks like an upright silver canister along side the condensor.
Can post a picture if it helps?
Hope that helps.
Jeff TT
Old Aug 21, 2005 | 03:08 PM
my car doesn't have that.
Old Aug 21, 2005 | 05:29 PM
nismo613's Avatar
Thanks a lot Jeff TT, Thats exactly what i was looking for! It helps a lot. A pic would be cool, but don't worry bout it if you dont feel like it. I could probably find it from your description. Thanks a lot. Sorry your car doesnt have that Riz.
Old Aug 23, 2005 | 01:13 PM
uti300zx's Avatar
amb temp
what year car do you have that has the outside ambient temp, because i have the climate control and my car doesnt have that?
Old Aug 23, 2005 | 04:35 PM
nismo613's Avatar
Mine is a 1990
Old Aug 23, 2005 | 04:49 PM
Jeff TT's Avatar
nismo613
Here is a picture of a UK spec zed with the bumper ( clip) removed, the circled connector is where the ambient air temp sensor connects to, the sensor itself is bolted to the back of the bumper ( clip) close to that same area with an 8 mm bolt.
Hope that helps
Jeff TT
Old Aug 23, 2005 | 06:34 PM
i think that's where the airbag sensor is now in the newer models.
Old Aug 23, 2005 | 09:15 PM
91zxtt's Avatar
That's an affirmative. The SRS sensor is bolted to the bottom side of the bumper and plugs in to a clip located in that same place.
mgk1068
Oct 12, 2015 09:32 PM
z31-Tom
Jun 21, 2013 12:38 PM
Rupe
Jul 29, 2011 04:57 PM
carfanatic
Dec 5, 2009 10:54 PM
duowing
Jun 25, 2008 12:23 PM
