New O2 sensor not working
Old 06-03-2020, 03:15 PM
kmac0913's Avatar
I'm at a loss and couldn't find anything online so hoping to get some help here.
I have a 91 n/a 2+2, I just recently replaced both O2 sensors and the passenger side (battery side) sensor is not working and the car runs like its in limp mode or something(bad/hesitant acceleration, loss of power and rough idle. I checked the harness side of the O2 sensor to confirm I am getting 12 volts. I checked the resistance of both new O2 sensors and they both (the functioning and non functioning O2) read about 8.8 ohms. I can see on ECU talk the passenger side O2 sensor stays on 1 (rich?) and the volt reading doesn't change. While the working O2 switches as it should 0-1 and changing volt readings to match. I also did a ecu reset by turning the pin on the computer.
O2 sensors are bosch 13091
Any ideas why the new O2 sensor isnt working?
huge thanks in advance
kmac0913 is offline
donaldg
03-18-2015 07:25 AM
scorpionp54
10-06-2008 11:47 AM
thxone
06-18-2006 04:29 PM
TheZerminator93
05-11-2005 08:33 AM
poneill
08-12-2002 09:37 AM
Quick Reply: New O2 sensor not working
