Need serious help guys
Old Dec 8, 2006 | 12:46 PM
813diablo's Avatar
Hey guys I'm new to the forum and new to the z in general. I bought a 90 NA a few months ago and now it has a running problem and I don't really know where to start. The car takes a while to start after sitting overnight and when I try to drive it it bogs down as soon as I touch the accellerator. I checked for codes and there was a code for ignition signal and a ECT sensor and FT sensor. I have checked for obvious things such as vacuum and fuel pressure. Where do I go from here? Any help would be appreciated.
Old Dec 8, 2006 | 02:08 PM
where you from? and sounds fuel/spark related... or vacummme but if you checked it maybe not. it is possible to miss stuff. but most likely spark if it is throwing an ignition code. do you know if the PTU was ever replaced? the early Z32's have a recall on them. the old ones look like a big heat sink. and could need to replace those sensors. if they are bad. comtimes **** gets thrown with an ignition code. but if sensors have failed cars usually run in safe mode and will run like crap somewhat similare to what you are discribing...
Old Dec 9, 2006 | 10:29 AM
91zxtt's Avatar
Start with the 3 error codes that were kicked out and move from there. Report back after you've addressed those three items.
Old Dec 18, 2006 | 04:58 PM
813diablo's Avatar
Ok, so i finally got a chance to work on the car today and I did a compression check, 3 of 6 are at 80 or below and the others are fine. The car has some autolites(of course, of wouldn't expect anything else, well maybe bosch) in it, they look fairly new though maybe the previous owner changed them before he sold it. I adjusted the tps senosr a bit and it ran a good 15 minutes before it started action like it was missing again. My fuel pump is herendously loud and it seem like the car was starving for fuel. I don't have a fuel pressure tester on hand but that is going to be the next thing I check when I get some time. Has anymore else ran into a bad fuel pump and make the car act like this?
Old Dec 18, 2006 | 05:09 PM
wow.. that 80 is gonna drag on your performance... and is a problem. is this a TT or an N/A? if the fuel pump is loud its most likely going out then.
Old Dec 18, 2006 | 05:29 PM
CanyonCarver's Avatar
Jack Of All Trades
Since it's starving for compression, I'd fix that first. Some fuel pumps are loud, including mine when cold.
Old Dec 18, 2006 | 06:01 PM
entropy31's Avatar
The Cake Is A Lie!
throw away those junk autolites and put in the proper, factory specced NGK plus.
Old Dec 18, 2006 | 06:11 PM
bardabe's Avatar
Bad Speller
80 compression = not good at all. way below factory specs. rebuild son. you need a rebuild.
Old Dec 18, 2006 | 09:55 PM
813diablo's Avatar
I thinking about doing the swap but tight on money right now so it has to wait. I have a feeling that its something electrical and when the cars warms up or when that particular component warms up its giving me problems. I downloaded the service manual and started looking for the feedback wire from the igniton module to the computer but I couldn't find it. The autolites deffinitely has to go, I just don't know what else has to go with it. On a scale of 1 to 10 how hard is it to do a tt swap on a 2+2? Parts that I would need that will save me time and aggrevation in the future, and just parts that is need to get the thing going? Any help would be appreciated guys.
Old Dec 18, 2006 | 10:08 PM
wreckedj30's Avatar
No Club Love
hmm, i think 300zxclub.com or tt.net...but i don't know if there the correct spelling of the site's...BUT...i got a spare motor out back...for sale...lol....Where you at?
Old Dec 18, 2006 | 11:03 PM
entropy31's Avatar
The Cake Is A Lie!
the TT swap topic has been covered ad-nauseum. a search on the subject will yield more than sufficient information to get you on the right track.
Old Dec 20, 2006 | 10:58 PM
813diablo's Avatar
anybody want to come and help me check fuel pressure? its a bring your own gauge kinda party!!!!
Old Dec 20, 2006 | 11:05 PM
813diablo's Avatar
so today I took off all the injector connectors and they all had pretty bad corrosion on them. I used a cleaner and took it all off, pluged them back in hoping that the car would drive fine. It doesn't, however I can drive it up to about 2000 rpm no problem and free reev to about 2700rpm before it would act like it was runing out of fuel. I am so tempted to just replaced the fuel pump but im not one to throw parts at a car. I want to know that I am giving it what it needs, saves me time and money. Does anyone know if this car has a dual stage pump? What are the chances its not the pump and the pump computer instead? I feel like im so close to getting this thing on the road. Off topic, I need opinions on the interior of the car. It has brown and white interior now, I want to go black and red, the ex is black and will remain that way. Do we all agree or does anyone have other choices?
Old Dec 20, 2006 | 11:15 PM
entropy31's Avatar
The Cake Is A Lie!
not a fan of red. i like dark grey and light grey together for interiors.
Old Dec 21, 2006 | 12:19 AM
dude.. you have 80 psi in two cylinders... they arent going to FIRE.. they are just gonna burn... you really need to work out that probelm i think over the other problems ou have.
Old Dec 21, 2006 | 05:30 AM
Jack Of All Trades
How can anyone come help you when no one knows where you live?
Old Dec 21, 2006 | 06:59 AM
813diablo's Avatar
I live in New Port Richey Florida, the car fires up and runs fine for a bit then it doesn't reev like it should. I think I'm just going to fo buy a fuel pressure tester. I am going to need it in the future anyway.
thxone
Feb 25, 2007 01:55 PM
902+2
South Region
Jul 3, 2006 07:28 PM
roneski
Sep 10, 2005 05:38 PM
ThermalWake
Aug 1, 2005 07:06 PM
Zrolimit
Jun 4, 2005 01:15 AM
